I HAVE MY REFRIGERATOR PLUGGED INTO A GFCI OUTLET, THIS JUST HAPPENED TWO DAYS AGO, MY REFRIGERATOR LIGHTS WERE NOT ON ,,,,CHECKED THE OUTLET AND IT UNPLUGGED FRIDGE AND NOW WHEN I TRY TO PLUG IT BACK IN....MY FRIDGE TRIPS THE BREAKER.....IF IM LUCKY IT WILL NOT TRIP BUT WHEN THE FAN TRIES TO START THE BREAKER TRIPS AGAIN
A GFCI detects shorts in an electrical system and isolates power to prevent that device from harming other components upstream. GFCI's do go bad so that possibility exists. However, I would recommend trying to plug in your refrigerator into another outlet in your kitchen that has a different GFCI plug. If it does not trip then the GFCI needs to be replaced. If you do not have another available GFCI outlet and you plug it into a regular outlet, your breaker for that service line MAY trip. Better off testing with another GFCI. If your second GFCI trips, then the problem is with your refrigerator...meaning you have a short in your refrigerator. If you think this is something you can troubleshoot...BE CAREFUL!!! Always unplug your refrigerator before going into the components of the refrigerator. One thing you can do is turn both the freezer and refrigerator temperatures OFF or to their lowest setting. Plug your refrigerator in and see if the GFCI trips. If it trips you have a major short...probably in the bottom of the refrigerator. If it does not trip, turn the freezer temperature on first and see if it will run without tripping the GFCI. If it runs, then turn the freezer temp OFF. Then repeat the process testing the refrigerator components. Ice makers have been known to generate shorts in the system as well. There are various ways to troubleshoot a fridge. If you do not have the required electrical troubleshooting skills then PLEASE call a service technician.
Posted on Nov 30, 2017
SOURCE: The fridge keep tripping the
Refigerators should NOT be on GFI-protected circuits. Problems have occasionally been reported when plugging a refrigerator, freezer or other motor-driven appliance into GFI-protected circuits. These appliances generally have a motor that pulls significant startup current. Due to the electrical characteristics of motors, the startup current can look like someone getting electrocuted, causing the protection system to trip. The best remedy is to connect these appliances to a non-GFI outlet. Usually outlets that are expected to serve such appliances will not have GFI's installed.
Posted on Apr 19, 2008
SOURCE: Fridge keeps tripping the circuit breaker
Your fridge should draw no more than 5amp. Presuming your breaker is at least 15amp there's a problem. Move to a different circuit first. If the condition persists check the start relay on the compressor. I have a suspicion the circuit may have another item you are not aware of.
Posted on Mar 01, 2009
get an inexpensive clamp amp meter (Harbor Freight has them). Turn off power to the plug. Remove plug from wall but do not disconnet wires. turn fridge OFF. plug the unit in the recept. turn on the power. set the meter for the higest reading (amps) & clamp it around the black wire. turn the fridge ON & observe start up current & the "run" current. If the fridge is within limits on the data plate the problem is in the wiring circuit, maybe a loose connection either @ the plug or the breaker. if there are several plugs in the circuit, the problem could be in one of them. In addition, if there is a gfi plug in this circuit, it could be faulty also.
Posted on Mar 02, 2009
Unless there is a dedicated circuit of 20 amps to the refrigerator this will continue to happen When your refrigerator goes into defrost and other things like lights fans air conditioners are on the same circuit it will have no choice to not trip the breaker. Try this turn the breaker off and how may thing in your house stop working? You need a 20 AMP circuit or this will possibly damage the compressor or weaken the breaker because it has tripped so many time. Thanks, Please rate my solution, I have done this work for 30 years. Thanks, Sea Breeze
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
[email protected]
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Posted on Aug 29, 2009
SOURCE: whirlpool refrigerator trips gfci outlet
Yes ,, if the fridge outlet is behind the fridge and therefore not accessible for use by counter top appliances .. then yes change it to a regular outlet.
The cause is probably the compressor, getting a bit noisy..electrical noise I mean.
Posted on May 05, 2010
