20 Most Recent GE PSW26SGRSS Side by Side Refrigerator Questions & Answers
0answers
No water and no ice
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
9/27/2011 7:39:09 PM • GE PSW26SGRSS... • Answered on Sep 27, 2011
2answers
How to change a ge refrigerator light bulb
It snaps in place by lifting the plastic cover. Then when you replace push it in then down. It has two tabs one on each end.
11/20/2010 9:34:08 PM • GE PSW26SGRSS... • Answered on Nov 20, 2010
Water Dispenser works intermintently, Ice dispenser never works
Called GE Service Dept. My refrigerator was way out of the warrant period. They came out and replaced the main circuit board at NO CHARGE.
5/1/2009 6:48:16 PM • GE PSW26SGRSS... • Answered on May 01, 2009
2answers
Different climate condition
unless you plan on putting this unit outside or on your porch, then the outside temps wont matter. refr's are designed to work from 50 f to 110 f, sorry dont know the conversion to celcius, but if it will be inside then you wont need to change anything.
during the hot times the unit will just run longer to keep the food cold and it will be fine.
1/8/2009 6:00:41 AM • GE PSW26SGRSS... • Answered on Jan 08, 2009
GE PSC23SGRDSS Icemaker not working
Take the ice maker out and pull the square cover off of it. If you have the type with a plastic "gear" (about the size of a half dollar) on it check to see if the tabs that hold it in place are not broken (it's common). The gear can get cocked or even fall off and that will cause the IM to stop working. If it's the type with a circuit board in it check it for loose connectors, etc. Both types have a thermostat in them to sense the temp of the freezer (must be about 15-17F for IM to work). It's rare that the t-stats go out but it can happen. The "motor module" is a high failure item (about $60 bucks and easy to replace). Let us know what you find.
1/14/2007 5:06:26 AM • GE PSW26SGRSS... • Answered on Jan 14, 2007
Ice & water dispenser not working - Part 2
Check under the front of the fridge for a small envelope that contains the wire diagram, that should let you follow the paths for troubleshooting. I don't have that schematic so have no "visual" way to guide you from here.
1/13/2007 6:41:17 AM • GE PSW26SGRSS... • Answered on Jan 13, 2007
The control board is likely gone bad or a wire harness inside the front came loose. With all those indications, I'd lean toward a dead board.
1/11/2007 5:21:06 AM • GE PSW26SGRSS... • Answered on Jan 11, 2007
GE Monogram Refrigerator damper stays closed
The issue is more likely the defrost timer in the freezer unit. They usually defrost every 24 hours to keep the fins of the evaporator in the freezer free of ice. If the defrost timer isn't working, you get a big lump of ice that cold air can't pass through to the vent in the fridge. The gurgling sounds are worrying and may be indicative that you need a top up of refrigerant gas, in which case you need a service call. You probably didn't need the mainboard or the damper.
9/19/2021 10:41:24 PM • GE Refrigerators • Answered 22 hours ago
GE GNE29GMHES model refrigerator freezer not keeping temperature , so what would cause that?
defrost timer might be stuck in the on position
9/15/2021 9:22:40 PM • GE Refrigerators • Answered on Sep 15, 2021
Looking to replace the vegetable drawer and assembly glider brackets for our GE refrigerator
no info generic answer --do online search and use make and model
9/13/2021 10:32:42 PM • GE Refrigerators • Answered on Sep 13, 2021
Model GSS25XSRCSS. How can I replace water dispenser supply line?
https://manualsfile.com/product/9xg1wl45y.html
9/11/2021 1:24:49 AM • GE Refrigerators • Answered on Sep 11, 2021
Side by side model GSRS3KLXHFSV. Lights are on. Why isn't it working?
SELF FIXES DO NOT WORK ON REFRIGERATORS THEY NEED SERVICE TECH TO FIGURE OUT IF FREON IS NEEDED
9/8/2021 1:24:33 AM • GE Refrigerators • Answered on Sep 08, 2021
How do you install the temperature sensor on a GE cfcp1nizc fridge
https://www.repairclinic.com/ProductDetail/1000342 There are video links on this page. I am unable to find an exact product match but this seems to match the model letters although it includes a few more letters. There is always the option to call GE service.
9/7/2021 6:01:46 PM • GE Refrigerators • Answered on Sep 07, 2021
GE PSW26SGRSS Side by Side Refrigerator Logo
Popular Tags
20 questions posted
Top Refrigerators Experts
Vish Iyer
Vish Iyer
Johnny 1000
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
different climate condition
  • Refrigerators
