20 Most Recent LG LFC21776ST 21 CF French Door Refer Cab Depth: LFC21776ST Refrigerator Stainless Steel Questions & Answers
Is the compressor running? If not check the condition of starting capacitor/relay.
LG LFC21776ST 21... | Answered on Mar 18, 2016
yes to both, and I believe to remove the light bulb cover you gently lift up and out to gain access to the bulb.
LG LFC21776ST 21... | Answered on Dec 12, 2014
Check the freezer:
If your fridge does not have an auto-defrost function then excessive ice-build up in the freezer can cause the beeping alarm. If you see a lot of ice build-up in the icebox or freezer, switch off the fridge and let the ice thaw. Once the fridge is thawed, the beeping should stop.
LG Refrigerators | Answered on Jun 15, 2020
Unplug the LG fridge and wait 20 minutes - Plug back into power - Many times the code will clear or reset. If not keep reading below... -The majority of the time it is the freezer fan causing the Er FF error code. The FF error code indicates that the freezer fan motor is defective.
https://removeandreplace.com/2017/08/27/lg-refrigerator-error-code-er-ff-how-to-clear/
https://www.lg.com/us/support/help-library/error-codes-refrigerator-CT10000021-1441392048805
LG Refrigerators | Answered on May 11, 2020
It needs more gas. Call a refrigeration engineer.
LG Refrigerators | Answered on May 08, 2020
see if voltage to water solenoid if yes check line for blockage if ok bad solenoid if voltage to it if no voltage bad board
LG Refrigerators | Answered on Apr 16, 2020
LG LFC21776ST 21 CF French Door Refer Cab Depth: LFC21776ST Refrigerator Stainless Steel Logo
3 questions posted
Top LG Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
freezer fridge suddenly stopped cooling
  • Refrigerators
