20 Most Recent Jenn-Air JFC2089HE French Door Refrigerator Questions & Answers
Sounds like cooling coils inside ref. that cools the water before the dispenser in the door.
These coils are in the back bottom of ref, behind crispers. They may be leaking.
Here is some more help.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
Jenn-Air... | Answered on Jul 22, 2018
could be you dispenser water solonoid valve, its on top, back of fridge behind panel
Jenn-Air... | Answered on Dec 31, 2015
Could be a fan needs oil or replacing. Find a fan outside and a fan inside.
Jenn-Air... | Answered on May 27, 2015
uSUALLY A PLUGGED OR CLOGGED EVAPORATOR DRAIN LINE IN FRIDGE OR BAD DOOR SEALS WILL ALLOW MOISTER ANS AIR TO CONDENSATE AND MAKE THE WATER PUDDLES
Jenn-Air... | Answered on Mar 21, 2015
DURING Summer time you will find fridges run longer. When the last time you had the condensor cleaned. Pull the fridge our and remove rear cover at the base. Make sure your fridge is unplugged. Use a brush and vacuum to clean the lint. watch for condensor motor and clean between coils.
Jenn-Air... | Answered on Aug 21, 2014
check if anything is in the way
Up is up and down is down......
What numbers is it changing back to? If you hear a fan that is good. Do you hear any 'clicking' by chance?
It is possible that for this, you may have a bad thermistor, but more information and or possibly an error code would help much more.
Jenn-Air... | Answered on May 05, 2014
Can you confirm your model number? I see what says that your model is a JFC2089HE above your post but knowing Fixya the model number there is automatically placed there and is most times incorrect, Thanks John Tripp Appliance 911
Jenn-Air... | Answered on Feb 21, 2014
Jenn-Air JFC2089HE French Door Refrigerator Logo
162 questions posted
Top Jenn-Air Refrigerators Experts
john h
Sheldon Dedek
Marvin
Marvin
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Jenn-Air Refrigerators
Most Popular Question
correct adjust open freezer drawer will
  • Refrigerators
