Lexmark Intuition S505 - multifunction  printer / copier / scanner   color Logo
Posted on Nov 20, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Set up wireless network
I want to connect my printer to a new router to get wireless function. Can't find a WAP reset button to push within two minutes for first method, and don't know where PIN setup is to enter the 8-digit PIN showing on the printer screen.
  • Official Brand Answer 3,344 Answers
  • Posted on Nov 20, 2012
Anonymous
Level 0:
Answers
3344
Questions
0
Helped
923828
Points
5508
You can run the Wireless Setup to connect your printer to your network. To access that, on your computer, click on Start > All Programs > Lexmark > Lexmark Printer Home > Settings tab > Wireless Setup Utility.
How to connect your HP DeskJet Printer to Wireless Network?
Follow the given steps to know HP DeskJet how to connect wireless networks. Start by placing your printer within the range of your wireless router and then turn on the printer. Now, locate the WPS Push button on both your printer and router. Then, press the WPS button on your printer. Within 2 minutes, press the WPS button on your router to establish the wireless network connection. https://connectmyprinter.com/how-to-connect-hp-deskjet-printer-to-wifi/
PS3 not connecting to DIR-619L D-link router.
Try resetting the -Link wireless router then configure the wireless settings.
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ON until the LEDs flash at the time the release the RESET button. (firmware version was 3.00, and upgraded to 3.05) Connect a LAN cable from the D-Link to your laptop/computer's LAN port, open the browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. (WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access). Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
2helpful
Installing OKI c3400n in Windows 7 32 bit
The c3400n does not have its own wireless capability. It must be connected to a wireless print server or to some wired network that has a wireless access point (WAP) connected to it. A third option is to use a home-networking wireless router.
Individual PCs must have wireless capability also, or they can't print over wireless.
Somewhere along the line the printer must get a local network IP address, i.e. 192.168.0.102. PCs usually use Dynamic Host Configuration Protocol (DHCP) to get an IP address.
But printers are usually manually set to a 'static' IP, because static IPs don't change over time.
Usually there is a security device called a 'firewall' to protect the wired network from unwanted wireless traffic.
So, you first require some form of wireless access.
The people who require wireless printing capability must have their computers configured to make an association to the WAP. Usually requires a passkey or password, depending on the wireless security method.
A port on the firewall must be forwarded to the port used by whichever network-printing protocol is being used to communicate with the printer. There are several possible protocols.
The printer must be set to an IP address unique within the private subnet, i.e. 192.168.0.0/16, used by the local network.
PC-based network-connected devices use IP (Internet Protocol) addressing, i.e. xyz.zxy.yzx.xzy
The printer must be connected to a network switch that is in some way accessible to the WAP. Residential/SOHO (Small Office Home Office) setups use a combination switch/router device, called simply: a router.
Most of the above is done automatically, but there are some set-up tasks that require user intervention. Electronic devices know how to configure everything, after they are given proper parameters.
All you need to do is check the above items. If the printer is found by MS Windows 'searching for network printers', the hard part is done. Then you just tell Windows to use the network printer.
3helpful
Hp printer says to press the WPS button on the router. What's that?
  • Wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections.
  • WPS lets you use push buttons or PINS instead of entering a network name (SSID) and wireless security by hand.
  • Push button: The WPS button is either on the product or a clickable button on a wizard or utility screen.
  • Personal Identification Number (PIN): The PIN is either on a product label or can be viewed on a wizard or utility screen. The PIN is entered for either the router or access point, or for the wireless device that wants to join the network.
How to retrieve password from wireless access point router zyxel -570u
Initial Set-Up
Plug your wireless router into the cable connection in your wall. Plug the connection cord into the "WAN" port on the router. Plug the router's power source into the wall and turn the router on. Connect your wireless access point to your router by pushing one end of an Ethernet cord into the WAP. Push the other end of the Ethernet cord into the "LAN" port on the router. The WAP connects your wireless devices to your router.
Connect your laptop or computer to the WAP. Click the "Start" button on your computer and then click "Control Panel." Click "Network and Internet" and then select "Network and Sharing Center." The "Network and Sharing Center" window opens.
Click "Set up a wireless router or access point." Click the "Next" button.
Follow the prompts to create a wireless pass phrase or security key. Write the key down in a safe location to ensure access later, if required.
I have bought an Epson Artisan 835 printer & can't get it to connect wirelessly to a Billion Router (BiPAC 7300G).This router is connected wirelessly to my i-Mac. I currently have the printer...
1) Please check your router setup whether it does not allow Wireless devices to ping against each other;
2) If it does not allow to ping (communicate) with each other, please disable it first.
3) Then please check your Epson wireless setup whether the DHCP function is enabled; if not, please enable it;
4) Please also input your network gateway, sub-net mask correctly into the Epson printer, otherwise the wireless communication with your network will not work.
5) Then switch off your printer and turn on again to recognize the new settings; and it should work
2answers
I dont know how to set a password for wifi
If the default password has been changed then -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
2helpful
2answers
I have lost my security code and cant use wireless
http://en-us-support.belkin.com/app/answers/detail/a_id/48
all routers have reset button on them, you can reset the router to the factory settings and set up yor wireless with the new code
1helpful
3answers
Network to include: PC1 that stores all shared files and is connected to printer and scanner. PC2 that can access shared files, printer and scanner via PC1. PC1 & PC2 are hard wired to the router...
You have to configure password for WAP to access the network. For this go to router management and configure the WAP password.
Revert back for more assistance.
1helpful
3answers
I lost my CD
You can reset your Netgear router/wireless MR814 router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings.
For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router/wireless MR814 router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '192.168.0.1' is the Netgear router IP address but you can find specific IP address in Netgear router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the router has been reset.
Feel free to get instant online Netgear router support at http://www.vtechsquad.com/netgear-router-support/ to fix Netgear router/wireless router issues.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
