Lexmark F4270 Plain Paper Inkjet Fax Logo
ANDREW DAMARI Posted on Nov 11, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
THE UNIT SHOWS ERROR CODE 1200 - Lexmark F4270 Plain Paper Inkjet Fax
  • Official Brand Answer 3,344 Answers
  • Posted on Nov 20, 2012
Anonymous
Level 0:
Answers
3344
Questions
0
Helped
923789
Points
5508
The 1200 error is caused by a cartridge carrier stall. This can happen if:
  • The print cartridges are not snapped in correctly.
  • The encoder strip is out of place.
  • A foreign object is blocking the cartridge carrier's path.
You can check this article on how to solve that problem: http://bit.ly/XypLZK
How to reset Bosch F19 error code
f19 is an error relating to heating, hence clearing a blockage did nothing, theres a good chance the heating element is dead you will need a multimetre to test it
tip
BMW Motorrad Fault Codes
10167 Output stage to electric fuel pump GS/A 1200 Idling irregular
Battles to start
Fault appears to start intermittently
Bike may start and ride, then will
appear to have fuel starvation
This unit is situated on the
left side of the tank. It is a
little aluminium unit with
fins on. Check the o-ring
of this unit. Unscrew the
unit and check for
moisture in the cavity
below it. Use moisture
repellent spray and
contact cleaner to clean
this device.
If problem
solving does not
work then
replace the unit.
10218 CAN-Bus Timeout: No
communication with KOMBI
(Instrument cluster) control unit
GS/A 1200 Test with diagnostic
system.
Clear fault code.
10219 CAN-Bus Timeout: no
communication with ZFE (Central
vehicle electronics) control unit
GS/A 1200 Instrument cluster does not activate
properly.
Instrument cluster activates partially
and then fades away.
May start on intermittent occasions
system.
If all else fails
replace the ZFE
control unit.
(Very expensive).
10444 Fuse activated for component block
3 (starter relay, Immo (EWS) ring
aerial, ignition coils, injectors)
GS/A 1200 There may be a short on the battery
terminals or elsewhere. Can happen
in conjuction with fault code 10219.
23971 Rear wheel speed sensor: Signal
implausible
GS/A 1200 Possible dirt on sensor. Dirt on wheel
where sensor lost contact.
system.
Clear fault code.
Replace sensor if
fault code reappears.
24052 Electric System under-voltage GS/A 1200 Starter motor battles to turn
Instrument cluster fades and then
reappears.
Check Battery Voltage
Check that the alternator
is charging battery
Check wiring to see that a
short is not draining
battery power.
Replace battery if
it is not charging
or
Service alternator
24971 Pressure In Front Wheel Circuit To
High
GS/A 1200 Check Wheel Pressure! Release air out of front
wheel to the correct
pressure.
Clear Fault Code
Oter fault codes here http://bike-manual.mozello.ru/bmw-motorrad-fault-codes
on Dec 20, 2016 • Motorcycles
What does code: H4-00 mean
The H4-00 is a low temp error in the fuser. This can normally be reset by doing the following at the machine:
On the button panel hit
pound, star, C, star
then enter 14, hit start, then execute on the screen.
This should clear any one-off errors
www.equipmybiz.com EquipMyBiz
2answers
Service error 140.10 transport motor
This is a generic error message that can be recorded for a wide variety of problems. Basically, any time the Report Server has problems initiating an application it will record this message along with:
- Application name (i.e. WindowsService_21, WindowsService_13, WindowsService_8)
- Error description (and that can vary widely). Examples: "The endpoint cannot be created.", "The report server has encountered a configuration errorr", etc.
For more help visit cbrtechsolutions
Printer shows error 1200. how do I fix?
The error 1200 is caused by the cartridge carrier getting stalled. That can be due to several causes. Here's an article in the Lexmark website to guide you to identify and, hopefully, resolve the problem. Just click on this link: http://bit.ly/9QxkWP. Hope this helps. If you need more assistance, place a comment so I can get back to this. Thanks.
My lexmark X4250 is showing an error code 1200.
It means that you have a paper jammed somewhere in the machine. Check in all the places where the paper moves for some scrap of paper that may be covering a sensor.
2helpful
2answers
E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Thanks for using Fixya.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
