Replaced water filter.
SOURCE: Kenmore coldspot refrigerator
checked the pump action????its a water valve powered by 110v.se if you can rig a test cord and plug into the valve itself see if you get water then. also check to tubing leading to the ice maker for possibly being frozen, as a result of poor water flow in the first place
SOURCE: Water doesnt stop after ice tray is filled
My amana sxd25s2w side by side, water dispener just stopped working all at once. I hear a click when pushing the bar, and the light goes on but no water. Also the ice maker is over flowing when it fills the tray. Are these 2 things related and I would like to replace the filter for the water , where can I find that. Please help!
SOURCE: Water dispenser in the door is dispensing water very very slow.
check and see if the ice is fully formed or look hollow / if hollow then run you a new water line to frig / if cubes are full then replace water valve.
SOURCE: leak
It leaks
Water can leak from these areas:
The bottom front of the refrigerator or freezer door
The back of the refrigerator
The inside ceiling of the refrigerator
The inside back wall of the refrigerator
Underneath the front of the refrigerator
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
Water coming from the back of the refrigerator usually comes from either the ice maker water valve or line (if there is an ice maker), or from the defrost drain pan.
Here's what to do:
Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem. This can be a big job – you may want to hire a qualified appliance repair technician.
In some refrigerators, the water from the defrost cycle is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain - usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
If the refrigerator is equipped with a water dispenser on the freezer door, check if the water line to the dispenser is leaking. Also, check the drip pan to be sure it isn’t out of place, broken or cracked.
SOURCE: Fridge water filter replaced now flows very, very slow
Hi .. first I would try and eliminate the filter as the problem. Remove the filter and try the water again. If the water flows strong, then the filter is the problem. If the water stills sputters and is low flow, then there is a partial blockage in the internal tubing , or a problem with the supply. If you roll the fridge out to get at the suppl. you could shut it off and disconnect the supply tube from the fridge, then turn the water on slowly to check the flow at the supply. If the flow is good there , then the blockage is internal.
