How to fix red ring of death
Not a simple question.
It depends on the 360 to be honest.
Whatever you do try do not do the "towel trick"
The red ring of death is usually an overheating problem and the towel trick will cause the 360 to overheat.
Look on youtube for "the penny trick/fix"
I'd recommend you send your xbox to a repair center though. In most cases they will repair it for free.
SOURCE: 360 Xbox problem Three red rings
3 Red lights problem is one of the most common problem of Xbox 360. You will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
SOURCE: xbox 360 2 rings
One red light signifies a major hardware failure or system error[4] , depending on which hardware failure or system error it is depends on how the problem can be fixed but in some cases there is no easy recovery and the console must be repaired or replaced. Two means the console is overheating and must be switched off and left to cool. Three, the infamous 'Red Ring of Death', means a general hardware failure and the console must be sent to Microsoft for repairs. All four red lights simply means that the console cannot detect its AV cable.
SOURCE: my xbox 360 has three red rings and one green in the middle
the 3 red rings are the worst and there is no way to fix it, i tried wrapping a towel around it and leaving it for an hour or so and that worked for me... the is a good old xbox remidee, but if that dosnt work then call the hot line and you will have to send it off.. the usually have it back in about a week
thanks, max
SOURCE: Xbox 360 problem with scratching disks
If your xbox is making that ring around your disc chances are you are playing your xbox standing up, if you lay the xbox down on its side this may fix the problem atleast it did for me. And as for the the midnight club freezing all the time it is still doing this on my xbox, copy the game to hard drive, and it should deffinitly limit the game from freezing, it worked for me.
Shifty Tazz
SOURCE: how do you fix two red rings on xbox 360?
just let it cool down,
two red light means that the internal temperature for the console just exceeded..
let it cooldown for a day..
when you use it, make sure there is no appliance near it...
