Samsung SyncMaster 713N 17" LCD Monitor Logo
ezhilarasan Posted on Aug 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Display not working but system functioning
I start my pc display coming for 1 second, suddenly display gone but the monitor power light signal working continuously (Green color) when switch off the monitor and switch on the monitor its displayed for 1 second again display gone. please give the solution
francoise cleofas
Level 3:
Genius:
  • Samsung Master 2,432 Answers
  • Posted on Aug 16, 2012
francoise cleofas
Samsung Master
Level 3:
Genius:
Answers
2432
Questions
0
Helped
298447
Points
6852
Tried with other monitor just to ensure if the problem is only with in the monitor. if the same problem, the cause it could be the inverter board for screen back light which has component being shorted.
5 Related Answers
Anonymous
  • 277 Answers
  • Posted on May 08, 2006
SOURCE: Monitor dark only when display PC, normal TV
hi have you checked your PC output? check it with another screen (whichever) and see if the output signal is good if soo check the cable and connections to your LCD check your PC for software configuraitions: 1) TV output 2) good resoulotion 3) media borad is strong enough to handle this LCD if all is good then maybe the TV borad is sending a low voltage/current then the LCD can see good luck
A
Anonymous
  • Posted on Jul 29, 2007
SOURCE: Monitor color dominated by blue; Green and red colors fade away as yellow and black
probly just the chord connectin from your pc to the screen. just buy a new chord.
Anonymous
  • 62 Answers
  • Posted on Oct 13, 2008
SOURCE: green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Anonymous
  • 51 Answers
  • Posted on Mar 16, 2009
SOURCE: Samsung SyncMaster 730B monitor green color problem
video controller card has gone bad need new video controller card.
Buddy Mcsparrin
  • 1684 Answers
  • Posted on Jul 22, 2009
SOURCE: No display on SyncMaster 920NW after reboot from power failure
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. Look in our monitor repair section for step by step repair guide for this model it should be the same power supply as the 930. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Advent 4213 not starting
check if it works with a external monitor, then ur display system has gone wrong
If i select source to pc display will become blank and power indicator blinking.
• You can check if the product is working properly using the Self-Diagnosis function.
• If a blank screen is displayed and the Power LED blinks even if the product and the PC are properly connected, perform
the self-diagnosis function according to the procedures below.
1. Turn the product and the PC off.
2. Separate the signal cable from the product .
3. Turn the product on.
4. If the product is working properly, the message appears.
In this case, if a blank screen is displayed again, make sure that there is no problem with the PC and the connection. The
product is working properly.
Is a blank screen displayed and does the power LED blink at
a 1 second interval?
1. This occurs when the power saving function is running.
If you click the mouse or press any key, the screen will be
turned on.
2. This occurs when two monitors are connected,
is and Magictune is running. In this
case, characters on the Magictune OSD may appear
corrupted. To run the Magictune, the must
be set to . Please restart your PC, set the
to and run the Magictune.
I have a hp a350 cpu.the problem is that the light of led has gone red,as before in working condition it was green. It can't start.the power to hardisk is also not coming.please tell a sollution.
As you say has become red and no power to the hard disk.
First check the power cable for any loose connections and check if it give power to the cpu and the fan placed on processor starts working as you start the power. If fan it starts and with in few seconds stops then your power supply/SMPS is weak or damage. So replace it for proper working of your computer. And if after power on all fines but red led on monitor and no power to hard disk Try to replace the hard disk power cables because they are not working because of it no operating system is detected and led of monitor is red. After replacing hard disk cables hard disk starts working and still no display or red led on monitor check the vga cable for loose connection or replace it.If you are using vga display from graphic card try to get display first from onboard vga slot.After it your problem will disappear and your pc run smooth and fine.
Asus p5gd-1vm motherboard no picture on display
in that case start system in safe mode after start safe mode please delet vga drive and then reinstalled it then after its worked.
1helpful
Vx900 no video display or on screen display. When powered up video signal displays for less than 1 second and then is gone. Power LED is stays solid green on, have tried other monitors and video signal is...
This monitor has a back-light problem and it could be a faulty inverter board or a faulty CCFL lamp.
For service parts and DIY info, check out LCD Parts, please click on this link to their WEB site :-
www.lcdparts.net
My W2207 monitor keeps going to sleep
Hi,First there is no signal from the PC . check if the display card has come out while moving the monitor, or just reinsert the display card in the PC , then boot the pc .
Display problem in my LG 15'' monitors
1. cheak the filament path diode,capacitor.
2. there is dry points in power section.
3. replaced 3842 IC supply capacitor 47/100v.
4. LOT sarounds. if in case near to lot one resistor burnt (12k ohm ) change the lot & capacitors,resistor
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
1helpful
HP desktop monitor problem
hi try this ,,,
  1. Ensure the video cable is connected (and connected to the correct video port).
  2. Turn off the monitor using the monitor's power button and then restart the monitor.
  3. Cycle the power on the monitor as follows:
  4. Turn off the monitor. The power light on the monitor should be off. Leave the computer turned on.
  5. Unplug the power cord.
  6. Wait 5 seconds.
  7. Plug in the power cord.
  8. Press the power button on the monitor to turn on the monitor. One of two things happens:
    1. The image from the computer displays on the monitor and you can use the computer again. This indicates that the monitor was unable to detect that the computer had awakened from suspend mode. Turn the monitor off when it is not being used or disable suspend mode. For some computers, updating the BIOS corrects these types of suspend problems.
    2. The power light on the monitor comes on but the screen displays one of the messages again. The monitor is not receiving a video signal from the computer that it can detect and use. Continue using these steps to adjust the Windows display resolution to the Monitor's native (default) resolution
    3. Connect the monitor to another computer that you know is working to determine if the monitor should be serviced or replaced:
      • If the monitor displays an image from another computer, you know that the monitor works. Troubleshoot the video connection and graphics adapter on the computer.
      • If the monitor remain blank when connected to another computer, the monitor signal processing hardware may be bad. The monitor should be repaired or replaced.
      hope it will work for u .. little_angel
3helpful
2answers
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
