LG LWHD1200FR Wall/Window Air Conditioner Logo
shirley galica Posted on Aug 03, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Window air conditioner
How to remove back of air conditioner condenser without breaking the coolant lines? Need to replace the fan.
Sal Sandoval
Level 2:
Habit-Forming:
New Friend:
  • Expert 56 Answers
  • Posted on Aug 03, 2012
Sal Sandoval
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
56
Questions
21
Helped
9343
Points
152
I have neve done this my self but I have seen it friends expert in the ac field doin it the condenser with the lines are removable true the front of the unit just look for the screws attached to the outside cover and unscrew them all about 6 of them and just pull the inside of it and you can work with it as you please.
2answers
My frigidaire air conditioner is making my apartment feel damp and when i took my filter out to clean it that part was damp too! What do I do to fix this?
You may have a clogged drain or the unit is installed without enough angle pitch for the water to drain to the back of the unit toward the outdoor section of the unit. I'm assuming it's a window air conditioner? The moisture condenses on the cooling coil near the filter and should drip down into a condensate drain pan, then the water should drain to the back of the unit into a pan at the condenser coil fan that is rejecting the heat outside. The fan blade usually has a ring on the outdoor fan that pick up the condensate moisture the fling accumulated water onto the hot condenser coil to evaporate it. Also the filter should not be touching the cooling coil. Make sure it in the correct slot. Some a/c cooling coil require a wetting agent that allow the water to slide down the coil and not pull off of the coil into the indoor circulating fan.
2answers
My goodman unit (1994) makes the loud noise, like a buzzing noise. The unit works, the blower blows air into the house, the air is cold, but the outside fan that blows across the condenser piping isn'
you need to replace your condensing fan motor. the noise you are hearing is the compressor working against a lot of pressure because the heat is building up in you condensing unit. Prolonged operation without an operating condensing fan motor will cause your compressor to burn up, and then you will have the cost of a compressor changeout to the cost of a condensing fan motor.
Radiator removal
IF the condenser is mounted by bolts through the radiator fins / cores simply undo and remove the bolts. Mostly the condenser is mounted on the front of the radiator panels while the radiator is mounted on the rear of the panels with separate bolts
My air condition window unit is spitting water how do I get to the drain line to clean it?
Hello, the drain line is usually located under the unit on the condenser side. If the unit does not have a drain then the unit is not tilted back enough to allow the condensate to be picked up by the condenser fan and splashed on the condenser to evaporate.
My fujitsu asu9rlq leaks water into house
Hello, first make sure the unit is tilted back in the window about 1/4 inch to help the condensate flow to the back of the unit. If the unit has a drain it will be under the unit usually toward the back near the condenser. Some window units do not have drains, instead they use the condenser fan blade to scoop up the condensate and splash the condenser to keep it cool and evaporate the condensate. So if you do not see a drain plug on the bottum the unit it does not have one.
2helpful
Radiator installation on 2003 Kia Sorento
That is a VERY easy radiator.
Loosen radiator drain plug and drain coolant from radiator.
Disconnect cooling fan connectorsRemove upper and lower radiator hoses after marking them to ease installation.
For vehicles equipped with automatic transaxles, disconnect transmission cooler lines at transaxle.
Remove air conditioner condenser fixing bolts and radiator bracket fixing nuts.
Remove the radiator, radiator cooling fan, air conditioning cooling fan and transmission cooler lines from the vehicle as an assembly.
Transfer all necessary parts (fan assemblies, cooler lines, clips, speed nuts, fittings, etc.) to the new radiator.
Reverse procedure to install.
Fill and bleed cooling system.
Toyota Corolla 1995. Quality of air conditioner reduced when stopped (traffic light) or moving at slow speed (condenced city traffic) No problem on the highway. Checked freon gas and fan. Understand that...
Normal, the ac heat exchanger condenser need air moving across the fins to remove the heat. While moving in town the condenser isn't remove the meat that is building up the it's aluminum fins. Even though the vehicle uses an electric fan. The fan is used to cool the engine temperature. If you Toyota is equip-ed with automatic transmission. The electric fan will need to pull enough air to cool the engine temperature, automatic transmission fluid, air conditioner condenser, and maybe power steering condenser to cool the power steering fluid. Later model of vehicles/trucks are using different refrigerants instead R134A in which you Toyota uses.
The simples way to explain is the ac remove heat from inside your Toyota and this heat is removed by the refrigerants inside your ac in the car. To cool the refrigerant this coolant is removed to the heat exchanger condenser located in front of the engine radiator. So, while moving at 60mph there is enough air flow through the radiator, ac head condenser, and other aluminum heat exchangers. GB...stewbison
1helpful
I have 2 Gibson AC's that are thru mounted that have worked well over the years with some water issues. WE have cleaned them without removing them from the windows with good success each year. Now, both of...
DONT DRILL A HOLE! It is to easy to drill through a refrigerant line and that's big problems. Water in the bottom of the unit is normal and there is usually a water slinger on the outside fan that blows the water on the condenser coil. Its good that you have checked the slope on the unit. It seems odd that both units started doing this at the same time. The water flows whereever it can from the front of the unit to the back. Probably the units are quite dirty and need cleaned. The dirt in the corners of the pans where the coils set can stop the flow of water through the pan.
1helpful
Sunbeam air conditioner
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
There is water sloshing around inside All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
if this helps please give me a fix ya
Top LG Heating & Cooling Experts
Mike Cairns
Mike Cairns
MattS1978
Level 1 Expert
Jay Finke
Jay Finke
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
