20 Most Recent Emerson Quiet Kool 10NW16K Air Conditioner Questions & Answers
Hello, first make sure the unit is tilted back in the window about 1/4 inch to help the condensate flow to the back of the unit. If the unit has a drain it will be under the unit usually toward the back near the condenser. Some window units do not have drains, instead they use the condenser fan blade to scoop up the condensate and splash the condenser to keep it cool and evaporate the condensate. So if you do not see a drain plug on the bottum the unit it does not have one.
Emerson Quiet... | Answered on Jun 12, 2012
Emerson no longer supports that air conditioner. But I'm afraid that even if they did - plastic trim is not an available part. Only the Mechanical workings would be available.
There is no hope for replacement but to find a non-working one, and strip it of its pieces you need.
Call Emerson Toll free at: 1-800-663-5954
to verify.
Thanks for using FixYa!!!
Emerson Quiet... | Answered on Nov 30, 2011
Diane, yo can find a inexpensive do it yourself kit, at just about any home improvement center or hardware store. You can cut it to fit and probably have enough left over to make another one, if needed later.
Hope this helped you.
Emerson Quiet... | Answered on Jul 20, 2011
If your device doesn't list wattage, but it does list amps, then just multiply the amps times the voltage to get the watts. For example:
amps x volts = watts x .30 if you dont have any information you are sol.
Emerson Quiet... | Answered on Jul 06, 2011
The fan blade sounds like its hitting the shroud for some reason. Sounds like you need to take it out of the case and clean the rear coil. The rear coil gets all stopped up with dirt, etc. You can wash it out but if you do be very careful not to get the motor wet. Unplug it when you are cleaning it out and let it dry out for an hour or so before you plug it back up.
Emerson Quiet... | Answered on May 30, 2011
You have to pull at the top edge of the vented pannel in the front. It is a little hard to pull. It will hinge down and give you access to the filter. I find it is easiest to clean AC filters by running water through them in the sink.
Emerson Quiet... | Answered on May 07, 2011
R.S.AIRCONDITIONER.
Mr Surender +(91)-9818551447 Shop No-5,Sharma Mkt,, Nr B Blk,Mother Dairy,Sec-31, Noida, Noida - 201301
HELPFUL?
Emerson Quiet... | Answered on Dec 27, 2010
E-1 air filter block. Cleani it.
Emerson Quiet... | Answered on Dec 07, 2010
May be blower or air filter blocked.
Check your air filter, the unit may be freezing up because of not getting enough air...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Emerson Quiet... | Answered on Sep 07, 2010
no as the freon is different. Sorry Tim
Emerson Quiet... | Answered on Aug 08, 2010
Oh yes,there are plenty to choose from,you can go larger,if it is a 220 volt,and get better service,it will cool better,and cost less,on electric.
Emerson Quiet... | Answered on May 28, 2010
Emerson Quiet Kool 10NW16K Air Conditioner Logo
26 questions posted
Top Emerson Heating & Cooling Experts
jdthefixer
kmuss1
Level 1 Expert
Pete Norton
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Emerson Heating & Cooling
Most Popular Question
remove
  • Heating & Cooling
