Heating & Cooling Logo
A
Anonymous Posted on Jul 24, 2014
Lg error code ch 05 - LG Heating & Cooling
MightyMikeJr
Level 3:
Master:
  • LG Master 409 Answers
  • Posted on Aug 15, 2016
MightyMikeJr
LG Master
Level 3:
Master:
Answers
409
Questions
0
Helped
314846
Points
1250
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset Air Conditioner Fort Lauderdale
  • Raymond Jul 15, 2022
    It works for me thank you
4 Related Answers
Rizwan Noori
  • 30 Answers
  • Posted on Feb 16, 2009
SOURCE: lg split system ch 05
Solution # 1, Check Condensor Fan Motor Capacitor 4uf or MFD
# 2, Check Motor Windings
# 3, Check Relay OR Defination Contactor
# 4, Check Connection Terminals
hope will help u 2 solve this
GOOD LUCK
Anonymous
  • 234 Answers
  • Posted on Apr 07, 2009
SOURCE: LG error CH 64
What is the model of the unit?
hvac1960
R Subramaniyam Iyer
  • 2133 Answers
  • Posted on Feb 03, 2011
SOURCE: error code ch 05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Steve F
  • 1361 Answers
  • Posted on Jun 16, 2011
SOURCE: LG Artcool about 4 yrs
CH 5 on these machines indicates a communications error between the indoor and outdoor units. Generally, it will require a replacement outdoor board assy to repair it. Lookup LG parts on the internet or ring them for your nearest Agent or parts stockist.
Foutcode ch 24 bij LG airco
Question edited for clarity and translated to English.
A CH 24 error code indicates a pressure switch error. To Resolve: Make sure the air filter in the unit is clean. Remove any items or reposition the unit so that the air flow is not obstructed.
Apr 25, 2023
LG Dehumidifier - Error Code List ' LG USA Support
How to fix error code CH 16 in LG AC?
It is a reminder to clean the filter
Split System Air Conditioner Considering this, what does Ch mean on LG air conditioner? It is not a problem but it is just the reminder to clean the filter of the air conditioner. ... LG Split System Air Conditioner Error code = 05 LG AC Fault Definition = Communication(Indoor Outdoor) - Communication Issue. Indoor Status = Off.
May 17, 2020
Error code LG CH 05,how to fix this
The CH05 error message means you have an indoor / outdoor unit communication error. It can be caused by any of the following issues:
  • No power on indoor unit
  • Indoor/outdoor unit power connection error / communication line not installed
  • Communication error caused by external noise
  • Indoor/outdoor unit communication circuit parts burned.
1helpful
What does the code on the screen mean flashes between ch and 05 ?
CH 5 on these units indicates a communications error between the indoor and outdoor units. Generally, it will require a replacement outdoor board assembly to repair it. Lookup LG parts on the internet or ring them for your nearest Agent or parts. 800 243-0000
2answers
Lg error code ch03
Hi sir
LG Package unit LKC3009C04 comming CH 03
LP - 60
HP - 280
Both circuit
One fan motor not good
What problem
LG Artcool about 4 yrs old error code CH 05. no heating or cooling. cheers.
3helpful
2answers
Error code ch 05
2helpful
What is error code ch o5
CH-05 Communications Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
4helpful
LG air condotioner with a CH5 error code
CH-05-Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Top LG Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
