My printer say Hex dump Mode, and is printer wried pages.. help..
SOURCE: Printer printing out code and screen message is: HEX DUMP MODE
it may be that the settings for the printer is not ok, or probably the software to make the printer work was not installed properly. Try by uninstalling the application for the printer by going to control panel on your computer, then click on add/remove hardware, look for the printer application and uninstall it, restart your system again and reinstall back the application. Then check the settings made on your printer too, if you don't understand how to do that then go through the printer manual for further assistant, if the problem still persist , then take the printer to HP customer service center for configuration and setup. Thanks
SOURCE: how do I reset dcp-8045d hex dump mode
Probably the easiest way to turn off the Hex Dump mode would be to reset all printer settings. There should be a reset menu that will allow you to reset the printer to factory defaults. After which it should recognize the new ram and print normally.
Testimonial: "the first answer I got worked like a charm. answer. turn off printer, hold down stop/exit while simultaneously turn printer back on. continue to hold down exit button until turns completely back on, whaalaa. fixed. thank you, been hex dumping for two days."
