Washing Machines Logo
Judith Waterson Posted on Jul 27, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fast spin not working. drum going round and draining but not spinning. Help!!!!
Have made sure no blockage in pipe. all clear. Can wash and water drains away but it just doesnt spin.. Help !!! Thank you
  • Anonymous Sep 04, 2012
    If you get any problem in washing machine then it is very frustrating. One of the most common problems in washing machines is that they won't spin. Usually this is happen in simple way, but sometimes it can be serious. If there is a simple problem then try to balance the load in washing machine. It would be helpful for spinning.
Level 3:
  • Hoover Master 17,130 Answers
  • Posted on Jul 28, 2012
Hoover Master
Level 3:
Answers
17130
Questions
0
Helped
3635788
Points
52372
Possible there is no drive voltage to the motor at this point of cycle, could be due to fault in the controller unit.
Need to check the voltage on the unit to confirm this case as the drain gets connected..
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Sep 04, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1915
Points
0
5 Related Answers
Anonymous
  • 25 Answers
  • Posted on Jul 16, 2009
SOURCE: beko washing machine wont drain or spin water stays in drum
the pump itself could be blocked or broken check inside pump first for any obstructions
Anonymous
  • 3 Answers
  • Posted on Feb 20, 2008
SOURCE: Hotpoint WMA35 - water will not empty and will not spin
Hi Debbie
Yes your machine will not spin if the water cannot drain... I do not have the machine in front of me but I would presume to think that you have a blockage in the water pump (or drain pump)
There is a normally a small pvc or plastic filter just before the pump and this would stop most big things entering the pump.. if not there could be a coin or button stuck in your pumps impeller.
Unfortunately if you are not technically inclined you will find it hard to access and open the pump otherwise just open the back plate on the machine (after removing the power socket from the wall) the pump is located at the bottom left and fairly easy to remove and open the plastic casing.
If this does not solve your problem please give more info........
Anonymous
  • 62 Answers
  • Posted on Jan 03, 2008
SOURCE: LG wft7014pp wont drain rinse nor spin
do you have a drip-dry function...as this cancels the spin cycle unless you select it yourself
mgprice
Mike Price
  • 744 Answers
  • Posted on Nov 09, 2009
SOURCE: My washer won't complete the final spin cycle. It
Hello, problem here is the spin control board is bad. Remove panel under the door and you can locate the spin control at the rear right of the machine screwed to the floor. Replace it and you will be all set. Mike
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jan 19, 2010
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Washer not draining but motor still hums
I would get to the water outlet pipe and blow hard down it to try and clear any blockage if not take the pump housing apart to clear the blockage eric
2helpful
MY WHIRLPOOL WTW5300SQO WASHING MACHINE WONT DRAIN WATER THE OTHER DAY IT WOULD NOT SPIN TO WRING THE CLOTHING THERE WAS A SMALL GARMENT LODGED IN THE SPIN BASSIN(?) WE TOOK IT OUT NOW THE WASHER WILL NOT...
Could be filter is blocked. Or drain pipe is blocked.
Fact it wouldn't spin, could point to blockage, as spin won't start if too much water in drum. Bad news is, it could be the water pump needs renewed.
Make sure drain pipe is properly connected to the waste pipe, and clear of obstruction.
5helpful
Error 03 not draining or going to spin cycle. Tub is full of water. I followed all the steps to drain and clean the hoses, pump, and the pump trap is clear and vanes spin fine. Nothing seems to be...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the blockage is in your plumbing and not in the machine.
Pl rate me ‘very helpful’ for the free help!
7helpful
2answers
Washing machine wont drain keeps bleeping ERR2
3helpful
2answers
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
1helpful
Washing machine washing and rinsing ok but no spin at all.Any suggestions please
90% of the time you will find there will be no spin condition if there is still water in the tub. Remove water completely and if you feel confident, pull off the plastic pressure switch pipe on the drum and select the washer to spin and drain or if you can, just spin. If spin now works, remove pump and check for restriction or blockage.Reassemble.
1helpful
Clothes remain dripping wet after the wash cycle is complete.
I assume you have removed the lint filter at the bottom of the machine and cleaned it out to make sure the pump is not stalled on a 1 pence or bra clip. Can you hear the motor start to spin? If not its probably because the water level switch is gunged up at the bottom of its rubber tube where it comes from the drum. Remove the top of the machine and locate the pressure switch - usually a round black or white device about 80 to 100mm across with a rubber pipe on a small spout 8mm diameter. Take the pipe clip off using pliers to compress it and move it back down the pipe. Remove the pipe and blow hard down the pipe to try and clear the blockage - you will hear bubbles blowing in the bottom of the drum water. Also you could very very gently blow into the switch stub pipe and listen for it changing over - clicks usually twice each way - blow - two clicks, release - two clicks. Restore swtch pipe and try the machine again. Good luck.
7helpful
3answers
LG Intellowasher cannot complete spin cycle.
Unplug power cable, remove top cover and inner panel, locate water level sensor on the right with 3 wires and a thin tube, remove the tube and puff into it until you hear water bubbling. This will clear any blockage caused by suds build up. Replace tube, covers and plug back in. It should complete cycles now.
Water in filter ,pipe doesnt seemed blocked couldnt find anything undid it all
DEFINATELY A BLOCKAGE OR RESTRICTION ON THE DRAINAGE SIDE.DISCONNECT THE PIPING COMMING FROM THE DRUM TO THE DRAIN MOTOR. MAKE SURE ALL IS CLEAR. REMOVE PUMP AND OPEN PUMP HOUSING TO INSPECT.(BLADE COULD BE LOOSE ETC). FINALLY RUN WATER INTO DRAIN PIPE AND EXPELL WATER BY BLOWING HARD.IF BLOCKED, RECTIY. REASSEMBLE AND TRY AGAIN.
3helpful
4answers
Kenmore front load washer will not spin
I had the problem where my Kenmore front load washer would not go into the fast spin. The repairman replaced the spin control unit and the motor with still no fast spin. He came this morning to replace the front control board and still nothing. He then decided to replace the door/lock unit and that is what did it. After about a month, now I am able to wash my clothes and not have to hang them up to drip dry enough for me to place them in the dryer. By the way, the manufacturer said that it was either the spin control unit or the front control board. I guess they will have to revise their fix for this problem.
Top Hoover Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
