Question about Hoover Washing Machines
Its not an error it means its in delay start mode. Hold down the delay start button (looks like a clock) for 5 seconds and it should clear
Posted on Aug 25, 2013
So glad I googled this because I thought it was an error ...? Thank you .. Lifesaver ! Lol happy new year :D
Thank you, it worked. Brilliant. I thought it was an error too, but no, exactly as Mark said. Thanks
Thank you so much woop woop IT worked
PERFECT
LIFE SAVER ;D xx
PERFECT
LIFE SAVER ;D xx
I had the same problem with my brand new candy and thanks to you I now realised I hit the delayed timer button :)
I have the same problem pressed the delay start button for 5 seconds it is not doing anything turned off from the main.
It's not an error it's just the delayed timer if it's 'F01".
Posted on Jan 25, 2016
SOURCE: error code E11 on hoover
Error code E11 is a dryer thermostat problem. The wiring, by design, is too short, and secured too tightly up and behind the digital display, and extends to a connector located on the machine's drum housing. When the machine is in motion, and there is a degree of drum movement back and forth, left to right, the wire disconnects resulting in Error code E11. Your issue may be that the wire is loose, and not fully disconnected (yet) hence the fault being intermittent. Error code E11 requires a service engineer to reattach the thermostat wiring in a way that allows for the drum housing to move, as per it's design, without the wire being disconnected from the drum housing connector, when the wash load becomes unbalanced during the wash cycle.
Posted on Dec 23, 2010
