Dryers Logo
ZLATAN M Posted on May 08, 2012
Circuit board repair
Where to send a circuit board for repair MULTI 1 MC 1368C E85416 94V-0
Anonymous
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on May 09, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
35
Questions
0
Helped
18320
Points
53
ACS repairs most makes and models of circuit boards. If you do not see your manufacturer in our LIST OF OEM MANUFACTURERS, don't worry. We can probably repair your item. Call to speak to one of customer service reps for help, 1-800-605-6419, email at [email protected], or use our Contact Page
bathroom light
How to check door switch for being bad
Hello Don;
My name is Peter. I am a retired field service appliance technician.
You need to purchase a multi-meter. This is a tool that will save you a lot of money in your self repair off all of your appliances. They Cost $20-25.00.
The two primary reasons your dishwasher may not start is your Bi-Metl thermal fuse and the door switch.
1.) Bi-Metl Thermal Fuse:
This is a thermal safety device that installs in the console. When the temperature inside the dishwasher gets too high, the bi-metal fuse burns out and breaks the circuit that allows electricity to flow to and from the main electric control board.
Substitution Part Number: W10258275 - Cost: $25.00
It is located next to your control board. Caution: Before touching you control board ground your self by rubbing your hands on bare metal. Static electricity will knock out a board.
a.) Turn power off at the breaker box.
b.) Disassembly the control panel to access the thermal fuse.
c.) Disconnect the two leads from the thermal fuse.
d.) With your multi-meter set on the lowest Ohms (Omega Symbol), put one meter lead on each contact.
e.) If your get a reading other than, '0' then the thermal fuse is bad.
2.) Door Switch:
This is located in you door handle assembly.
a.) Lift the switch off the two retaining pins.
b.) Disconnect the two contact wires.
c.) Using your multi-meter the same as above - hold the switch button in with the two meter leads on each contact. Here, you also are looking for '0' Ohms if the contact switch is good.
How to set a clock on a deh-3300ub pioneer
Press SRC/OFF and hold until the unit turns off. Then press the Multi Control (M.C.) and hold until function name appears in the display. Turn M.C. select the initial setting. After selecting, perform the following procedures to set the initial setting. 1. Press M.C. to display the setting mode. 2. Press M.C. to select the segment of the clock display you want to set. Hour - Minute. 3. Turn M.C to adjust the clock.
11helpful
2answers
I have a problem with my MC-2000ES motor control board. The HV BUSS LED is not on and therefore no DC voltage to run the motor.I have checked the diodes and SCR circuit and all look OK. I believe there is...
just change the Diodes D4015L and SCR´s S4015L whit a caugting buy the new change and ready or is a MC-2100 w / transformer just change the MOSFET IRF250N
No more receive
This scanner uses SMT parts and a multi-level board. If RF from your Yeasu cooked it, you have no choice other than to send it in for repair. Unless you have access to SMT equipment and understand you can't repair traces on a circuit board with multiple levels, you are sunk. Send it in for repair. They will shotgun the board and get it back to you.
1helpful
4answers
Acer recovery disk download
i keep getting this on my lap top and cant get ride of it can you help me??
Multi (0)disk(0) rdisk (0) partition (2)\Windows\AppPatch\drvmain.sdb
TRAP 00000006================EXCETION================
multi(0)disk(0)rdisk (0) partition (2) \WINDOWS \system32\DRIVERS\WMILIB.SYS
multi(0)disk(0)rdisk (0) partition (2) \WINDOWS \system32\DRIVERS\pci.sys
tr=0028 cr0=80000013 cr2=00000000 cr3=00039000em32\DRIVERS\isapnp.sys
gdt limit=03FF base=0003F000 idt limit=07FF base=0003F400compbatt.sys
multi(0) disk(0) rdisk(0) partition(2) WINDOWS\system32\DRIVERS\BATTC.SYS
cs:eip=0008:0009F737 ss:esp=0010:000600EC errcode=0000IVERS\pciide.sys
flags=00010012 NoCy NoZr IntDis Down TrapDis ystem32\DRIVERS\PCIIDEX.SYS
eax=00000000 ebx=00000100 ecx=0000BB40 edx=00030715 ds=0010 es=0010sys
edi=00060D4C esi=00000000 ebp=00060E34 cr0=80000013 fs=0030 gs=0000s
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\ACPIEC.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\OPRGHDLR.SYS
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\PartMgr.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\VolSnap.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\atapi.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\disk.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\CLASSPNP.SYS
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\drivers\fltmgr.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\sr.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\KSecDD.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\Ntfs.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\DNIS.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\Mup.sys
2answers
Unable to boot into windows
what are the things that you added recently, hardware(additional hdd, memory, video card) or software (antivirus, office, etc games.) try running a hard drive diagnostics, usually computer manufacturer install a hdd diagnostics on their BIOS that you can run. hit me back on the results.
2answers
Boot problem
you have to repair or reload your operating system
1helpful
Safe mode....unsafe.
Your PC is stuck in safe mode startup
I would suggest using the Windows Disk, if you have one, go through normal windows installation. At the point of installation just after pressing F8 it will detect windows exists and offer you a repair option press R to repair
Top Dyson Dryers Experts
NOEL
NOEL
john h
ADMIN Andrew
ADMIN Andrew
Are you a Dyson Dryer Expert? Answer questions, earn points and help others
