20 Most Recent
Dyson AM07 Tower Fan Questions & Answers
Replacement fuse
There is not only 1 fuse but there is inside the coil of the electric field a little temperature fuse its most times inside a insulation tape
My dyson fan was serviced last winter by you as it was recalled now it does not work , the lights come on and the motor runs 2 seconds and dies
Hi Kathy, it's Jack at Dyson.
I'm sorry to hear you're concerned about your Dyson fan heater. However, this could be normal behavior from your machine, as the heater would usually display an error code if was an actual fault.
If the target temperature you've selected (shown on the LED display on the front of the machine) is equal to less than the ambient room temperature, the machine may run momentarily until the intelligent thermostat shuts it off.
The solution is to raise the target temperature, using either the remote or the controls on the base of the machine, until the heater runs. It's important to keep in mind that what you're selecting is the temperature you want the heater to heat the room to - so the machine won't run if the room is already at or above the target temperature.
I hope this helps, but if you'd like to discuss this with one of our experts you're welcome to call us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
How do I disassemble a Dyson Cool AM07?
Hi Glennis, it's Jack at Dyson.
I've included our Getting Started guide for AM07 below. To disassemble it, you would just need to reverse these steps. To remove the loop amplifier, hold the main body firmly and twist
the loop amplifier anti-clockwise to unlock.This may be a bit stiff if the fan is brand new and hasn't been disassembled before.
I hope this helps, but if you need further guidance from our experts, just give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Dyson instructions
Hi there, it's Jack at Dyson.
The AM07 Tower fan is quick and easy to assemble - our Getting started video guide shows you how:
I hope this helps, but if you have any additional questions you're welcome to give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Need a manual Dyson am07
You should find our video guide helps in getting started with your new AM07:
However, if you would like a .pdf file of the AM07 User guide, please email me directly at
[email protected] so I can send this to you.
Dyson Am04 model no longer turns on due to a power surge. What part is required to fix it? TIA.
First thing is to check the wall socket. Use a desk lamp or something similar and plug it into the socket you use for the heater. If the lamp works so does the socket. Next check the fuse. UK machine have a fuse in the plug, other countries use different systems.
If all these check out OK the surge may have damaged a circuit board inside the heater. Only a Dyson specialist could help you with that.
8/17/2020 3:11:16 PM •
Dyson Dryers
Answered
on Aug 17, 2020
