I had a 'clean the ctd sensor' error. Cleaned it now it prints half the page in watercolors.
I had a clean the ctd sensor problem as well, as a problem with toner that I had ordered. The problem for me was that with Dell, when I called for support, the young lady on the other end of the phone although nice, was difficult to understand, and did not clearly define how you get to the ctd sensor.
After much prayer, (seriously!) I finally figured out how to get to the area I needed. With Dells instructions, I took the fuser out, thinking it was the transfer roller. The fuser is NOT the transfer roller, the transfer roller in the item that you see when you open the front entirely and look straight down. The difference is that the fuser is the first item out and has lift up blue tabs, while the transfer roller has blue tabs on each side that must click into place to hold and position the transfer roller properly. Once you get this out the ctd sensor is easily accessible, and can be cleaned. After, getting the ctd cleaned, and then replacing the bad toner cartridge, my machine once again worked.
Sherry McGregor Timberwood Mountain Realty,
CTD Sensor Error
Error 092-310
Error Code: 00002000
Restart Printer
Reseated fuser and imaging unit and restarted printer, still getting error.
I have the same issue and seems to be related to the humidity which will give a CTD Sensor Error # of 092-310 and the ERROR CODE # 00002000 .I resolved this with a Dehumidifer set to 45 % to remove the water out off the air which is in the room my 6128MFP was in . It takes some time but you must keep the side door and the front Panal Door cracked open to help draw air from inside the Printer. Also unplug the printer before you power back up.
