SOURCE: my canon mp810 is giving
I will suggest you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see what happens. let me know if additional information is required.
SOURCE: Error 5020 scanner lock switch
Does anyone know how to fix error 5020 release the scanner lock switch and turn the power off & on.The Cannon MP810 Printer. Please Help!Thanks
SOURCE: printer canon mp810 displaying 5020 error
Hi
This maybe a small bit of paper in the rollers somewhere you need to find it or it is need of a good clean.
You can also try this.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: Hello, I have a Canon MP810 printer and the screen
I have just read it on the other forum..try this one
Error Code 5020:
Scanner lock switch locked. [5020] Release the scanner lock switch and turn the power
off and back on.
Turn the machine off, unlock the scanner lock
switch, then turn the machine on again.
Hope it helps.
When you follow the instructions do you just get the same error message or can you not perform the requested operation?
Get the same error message.
