20 Most Recent
Canon PIXMA MP810 All-In-One InkJet Printer Questions & Answers
Changing the print size on a Canon MP 810
Using Gimp , I imagine you are using Linux not Windows. Download the latest driver from the Canon website and make sure its the correct one for Linux. I am not aware of any settings within the 810 that can be changed as print size is governed by the driver and not the printer. Make sure you UNINSTALL the old driver and don't just DELETE it .Good luck
Error code 6000
Error 6000 is a service call error, meaning that the printer needs to
be taken into a canon authorized service facility for repair.
This is a line feed error, with the problem originating from the timing disk film or the printer's logic board.
My canon MP810 all-in-one printer, i've cleaned
Printing with an empty ink cartridge may cause printer malfunction. U051 / U052
U053 / U059 The ink cartridge may not be set properly, or an ink cartridge not supported by the printer is installed.
Install the proper ink cartridge.
If
one of the ink cartridges is missing, this error will occur. U075 /
U076 The ink cartridges are not installed in the proper position. Install each ink cartridge in the proper position. U140 An ink cartridge not supported by the printer is installed.
Install the proper ink cartridge. U161 / U162 A used ink cartridge may be installed, or the ink cartridge may be empty.
Replace the ink cartridge.
By
pressing the OK button, printing can be done without replacing the ink
cartridge. However, the remaining ink amount cannot be detected
properly, so the function to detect the remaining ink amount does not
operate. READ/WRITE MODE Since the memory card is currently
write-enabled, printing is not possible.
Set READ-ONLY MODE ON. NO
PHOTOS ON CARD Some images in the memory card may not be in a supported
format. images listed below cannot be printed directly from a memory
card. Print them from a computer.
The waste
ink absorber is a part inside the printer, which absorbs ink used in the
cleaning operations, etc. CHECK PRINTER Turn the printer off, and
remove the power plug from the outlet.
About ten minutes later, plug it in again, and turn the printer on.
If
the problem is not resolved, the printer may require servicing. Please
contact your local Service Center.
Change language to English
1 - Press Home button, wait 5secs. and select the tool icon
2 - Press the right button and select what looks like 2 slides with small tabs
3 - Press the down button 4 times (5 times if you have blutooth) and press OK
4 - press up/down and select the language you want and press OK
How do I change the language
1 - Press home button and after 5secs select the tools symbol and press OK
2 - Press Right(Forward button and select wht looks like two slides with small tabs
3 - Press down button four times (five times if you've bluetooth) and press OK
4 - Press up/down to select the language and press OK
Cd tray error Canon Pixma MP810
Sorry a little late only just read your problem.
The location is not the bottom tray feeder but the disk tray. In settings change your media type to "Printable Disk" the paper scource should automatically change to "Disk Tray" and hopefully every thing will work OK.
My printer isn't producing any ink?
The manual says:Follow the directions given in the Easy Setup Instructions to install the Print Head.If the Print Head is already installed, remove the Print Head once and then reinstall it.If the error is not resolved, the Print Head may be damaged. Contact your Canon Service representative.take care putting the head in as discribed in the setup description.I'll think it over if there could me more
