Dell printer 1720 usb port print feature not working. I tried using the Com port with the same printer on a different computer and the printer works fine. I also, downloaded new drivers for the 1720 printer and it still doesn't print.The computer that i am trying to print from is a Inspiron E1405, this laptop doen't have com ports, only USB ports. Please help!!!!
You can get a usb adapter to printer comp ports on ebay eBayeBay
SOURCE: problem connecting and printing my lx-300 matrix printer
You need to get a paralell to USB cable, like the one on the following link: http://catalog.belkin.com/IWCatProductPage.process?Product_Id=20651
SOURCE: can't print using USB connection
Unplug printer and un install software. Delete printer in printers folder. Restart pc. Install software first and then connect printer. Also make sure your usb drivers is correct.
SOURCE: How to configure the Zebra S500 using a USB to Parallel adapter?
The Zebra Stripe S500 has a RS-232 SERIAL interface using a DB-25 connector . You'll need a USB to SERIAL converter, not parallel. Be sure that the baud rate and data/stop bits are set the same on the printer and interface converter. Generally speaking, use the fastest setting possible (19200 baud) unless you encounter problems.
SOURCE: USB port problems with hp printer
There are few things to remember using USB.
To remove currepted USB drivers its not enough to remove your printer drivers.
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
SOURCE: UPS Thermal 2844 Connection problem(USB)
Add the printer as a Local LPT1. Then go into the properties and switch the port to a USB port. Try a test label. If it doesn't print, go back to properties of the printer and switch it to another USB until it does. If all else fails there is a remove utility included with the Zebra drivers you downloaded. You can remove all zebra related drivers and printers and then reboot. The PC should redetect the printer when you turn it on.
