20 Most Recent KitchenAid KSB580CR - 5 Speed Blender Custom Metallic Series, Chrome Questions & Answers
Blender jar leaks
Check the blade assembly if it is loose tighten it up. If it is worn out or cannot be tightened up then buy another jug complete with blade. If it is the glass jug model then the blade assembly is available without the jug and they also have a replaceable seal at the base.
12/19/2013 6:03:53 PM • KitchenAid... • Answered on Dec 19, 2013
I need a coupling for a kitchenaid blender Model
I know it's a late reply but I have plenty here in New Zealand.
11/2/2019 5:46:26 PM • KitchenAid... • Answered on Nov 02, 2019
The wing nut on my kitchenaid blender has broken do i have to buy the whole blade assembly?
Hiya, Sorry you are experiencing an issue with your blender. Sadly you will have have to replace the whole blade assembly in this instance. Please see our help video for your perusal. https://www.youtube.com/watch?v=c-3qS7k3KeM I hope we could help you resolve your issue :-)
10/23/2019 8:26:03 AM • KitchenAid... • Answered on Oct 23, 2019
How do I replace blender rubber clutch for Kitchen Aid blender
Hiya, Sorry you are experiencing problem with your appliance. We have created help pages and videos to help you resolve this issue, please see the relevant links below for you perusal: https://www.kaparts.co.uk/Help/KitchenAidHelp/KitchenAidBlenderHelp/KitchenAidSplitCouplerRemoval/tabid/180/Default.aspx https://www.youtube.com/watch?v=Qy9gCwSgUVg https://www.youtube.com/watch?v=nhnuaSCoVjQ Hopefully you will find our information helpful. Should you require any help, please don't hesitate to contact us.
10/23/2019 8:25:48 AM • KitchenAid... • Answered on Oct 23, 2019
Pitcher stuck on base
You will likely need to replace the beaker anyway, the drive which is now melted to the motor coupling is only supplied as part of the beaker/blade assembly. You will also need a motor coupling.
4/9/2018 12:02:13 AM • KitchenAid... • Answered on Apr 09, 2018
Why does Kitchenaid blender KSB655 have burning smell during operation?
If it is not something to do with the coupling (rubber one on the jug bottom and hard plastic one on top of the motor) then I'd be checking that the cutter shaft is not getting hot. If it was the motor playing up normally they pop into error and stop with flashing lights. The switch panels give very little trouble.
1/18/2018 4:44:28 AM • KitchenAid... • Answered on Jan 18, 2018
Kitchenaid KSB655C5 blender locking collar doesn't go down on one side when assembled. Both sides of locking collar are away and symmetrical when off the jar.
I would say pull it apart again and fiddle about with it a bit paying some attention to that spring loaded ring that's causing you grief. I don't have one here to look at but I know I've seen that problem before and it's something to do with that ring underneath needing to be turned to a certain position so that it engages properly. There are some notches in it that need to be in a p[articular position. We never saw that version for too long, the following model had a plastic beaker without all that rubbish on the bottom.
3/24/2017 9:03:57 AM • KitchenAid... • Answered on Mar 24, 2017
KitchenAid model ksm90wh blade holder will not turn even with out blades
You will probably fine that the fuse gear has failed. If the motor runs and the planetary and front drive does not turn then the solution is only going to be found inside the gearbox.
3/24/2017 8:55:43 AM • KitchenAid... • Answered on Mar 24, 2017
My kitchenaid blender won't work. Lights for all the settings come on but motor won't start
I expect you will find that the motor is open circuit. There is a thermal fuse incorporated into one of the field windings which can be replaced with a bit of messing about. A job for a retired appliance service person if you want to keep the price down. Did one today, took about an hour from start to finish.
12/20/2016 6:48:06 AM • KitchenAid... • Answered on Dec 20, 2016
I have 3-year-old Kitchenaid Blender, model KSB1575CCUO. The motor started occasionally making a grinding sound, especially on high speeds, but blades still turn. Does the motor need oiling?
it could be failing bushes for the motor take it to an appliance repair shop for an inspection of the motor to check for bush/bearing problems
12/10/2016 10:03:33 PM • KitchenAid... • Answered on Dec 10, 2016
My kitchenmaid pitcher is stuck on the mixer. it still mixes, it won;t detach
The coupling on the motor has become bonded to the coupling on the beaker. Maybe it was moving about excessively and the 2 plastic parts have fused together. You can expect to have to replace the motor coupling and at the least the blade assembly or possibly the whole beaker depending on model. Knowing what you are up for needing to replace now if you wish to get it off put a litre of water in it, put the lid on and turn it on high and wobble, wriggle it about until it is able to be lifted off.
8/30/2016 8:22:11 AM • KitchenAid... • Answered on Aug 30, 2016
When the mixer is put on all the led lights flash but mixer would not start
Most likely the motor will be open circuit
7/7/2016 7:49:41 PM • KitchenAid... • Answered on Jul 07, 2016
How do I remove the motor on kitchenaid Diamond blender, removing the coupler?
Put the base back on, determine which way the motor normally turns from the top when running. Drill a hole in the edge flange of the driving coupling. Stick a punch or screwdriver in the hole and whack the punch with a decent hammer to shock the coupling in the direction it normally will be turning. Sometimes it's a few whacks, sometimes a whole lot more but eventually they always come undone. Replace the coupling.
5/31/2016 6:17:11 AM • KitchenAid... • Answered on May 31, 2016
Where is located the fuse on kitchenaid blender motor?
dont normally have a fuse self insulated plugs for safety fault is either the plug, motor or switch with a continuity test light or meter you need to check there is a constant circuit at the two plug prongs
5/27/2016 11:33:48 PM • KitchenAid... • Answered on May 27, 2016
How do I check for power to motor?
If you have to ask how to do it then there is a good chance that you will not have the equipment to do the check and if you do have a meter you will be electrically unsafe doing it. For starters you need a multi meter, disconnect the motor from the speed control pcb and check it for a circuit. It is more likely that the motor or pcb will be faulty, cable faults on blenders are very rare but now you have your meter you can disconnect the cable from the pcb and check each wire for a circuit.
1/24/2016 6:06:51 AM • KitchenAid... • Answered on Jan 24, 2016
What is the thread size on the knife cutters of the Kitchenaid KSB555.
The thread that the driving clutch screws onto measures 6.2mm with my calipers measuring the thread. Confirming it is left hand thread.
9/11/2015 11:47:03 AM • KitchenAid... • Answered on Sep 11, 2015
Looking for a used jar assembly and lid for model 4KPSB148 BLENDER
cruise around the weekend markets, flea markets , garage sales, pawn shops for this but I don't like your chances about the same as getting a new one from the manufacturer unless you haven't already tried that option
7/31/2015 1:31:08 AM • KitchenAid... • Answered on Jul 31, 2015
KitchenAid KSB580CR - 5 Speed Blender Custom Metallic Series, Chrome Logo
2 questions posted
Top KitchenAid Blenders Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
View Most Popular
KitchenAid Blenders
  • KitchenAid Blenders
Most Popular Question
blender jar leaks
  • Blenders
