If it is not something to do with the coupling (rubber one on the jug bottom and hard plastic one on top of the motor) then I'd be checking that the cutter shaft is not getting hot. If it was the motor playing up normally they pop into error and stop with flashing lights. The switch panels give very little trouble.
SOURCE: burning smell when used
No need to oil it. The carbon brush maybe sparking already it is located inside the motor. It is due to damaged Armature or overloaded motor.
SOURCE: Need new glass container for kitchenaid blender.
They are usually in stock here:
http://kitchenaidblenders.co.uk/Home/tabid/36/c/KitchenAid-Blender-Spares/CategoryID/6/Default.aspx
SOURCE: Waring 34BL87 blender is loud and gives off a
3 in one oil on bottom rolling metal. let it soak in and rotate. oil again when it screeches. You do not have to disassemble the cutter. That will take a special long nose pliers. Smells burnt , it is worn out. replace parts or toss.
SOURCE: My blender had a burn smell and doesnt work could the motor be burned?
They don't make them like they used to. The smell could be the windings on the motor or it could be the control board.
