Question about KitchenAid Blenders
KitchenAid model ksm90wh blade holder will not turn even with out blades
Posted by leona mackey on
Ross Keen
  • KitchenAid Master
  • 1,364 Answers
You will probably fine that the fuse gear has failed. If the motor runs and the planetary and front drive does not turn then the solution is only going to be found inside the gearbox.
Posted on Mar 24, 2017
Why doesn't blade spin?
Either the coupling from the motor with the fingers on it is not really attached to the motor shaft or the drive on the blade that engages with it is not attached to the blade shaft. One other thing is that on some models if the rubber jar seal between the beaker and the blade carrier is in the wrong place it can raise the blade drive to not engaging properly with the motor coupling. The gasket goes between the jar and the blade carrier, not under the blade carrier.
Sep 04, 2015 | KitchenAid KSB3 Classic Work Top Blender
I have a kitchen aid blender with a polycarbonate jar. The jar leaks at the blade. I noticed it has a plastic nut on the bottom with left hand threads. However the nut will not fit over the drive gear...
Older KitchenAid blenders had a jar that was made so the blade assembly could be removed for cleaning. On the newer models the blender jar and the blade assembly are all one unit so you have to purchase a new jar to get the blade assembly. All of this is dependent on which model of blender you have.
We would be happy to help you. Please a give us a call at 1-800-339-9297 we would be happy to help! One of our repair technicians can talk you through the repair over the phone free of charge. On the bottom of your blender is the model and serial numbers; have these handy when you call so we can help you order the correct part.
We have several blender jars on our Web site http://www.mendingshed.com/kitaidblen.html for KitchenAid blenders. If we don't have the blender jar that fits your model in-stock we can order it and ship it to you. Please contact us with any further questions. You can also email your model number or questions to [email protected]
Sincerely,
Mendingshed.com Staff
Aug 28, 2011 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
The blades stopped turning in the middle of blending a batch of hummus Its is a Kitchen Aid blender about 10 years old
Does the motor still work if you take the pitcher off of the base? If so, the rod that's in the blade assembly is probably corroded. The blades are connected to a metal rod that passes through a brass tube through to the piece that makes contact with the motor when you put the pitcher on the base. The grease wears down eventually and if you don't pulse and run the motor for a long time at once, the heat can corrode the bar and cause the blade to stop spinning. You can either disassemble the blade unit, or buy a new blade unit online. google blender parts and you can get one for $10
Dec 22, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
The lights on my cuisinart blender come on but the motor just stopped working
Using your blade holder, turn the motor from the blade end. 1 or two turns. Tak the blade holder out, Plug in an test Sometimes the brushes in the mototor lose a good contact. SGood Luck -Ned-
Sep 19, 2009 | Cuisinart SPB-6 Smartpower 6 Speed Blender
Unit seems to work fine, but when the pitcher is attached, the blade hardly spins. It seems like it is loose or something. I can manually spin the bottom piece of the blade assembly, but the blade itself...
Depending on the age of your blender, a new blade assembly may be available. I would recommend calling Kitchenaid Customer Service for pricing. Their toll-free telephone number is:
1.800.541.6390
Jul 27, 2009 | KitchenAid KSB3 Classic Work Top Blender
Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Jun 06, 2009 | KitchenAid KHB300 Handheld Blender
How to know a NEW from the old polycarbonate jug\pitcher that cracks near blades.
The "code" you are seeking is found in the serial number, which has a specific way of noting when the unit is manufactured.
Buy with confidence and hang on to your dated sales receipt. If the blender leaks, take advantage of Kitchenaid's 1 Year warranty by calling into Kitchenaid Customer Service.
Their toll-free telephone number is 1-800-541-6390.
May 24, 2009 | KitchenAid KSB560WH 5-Speed Blender
Blender blade not turning, rotating piece on base not connected
this is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 24, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Blenders Logo
354 people viewed this question
Top KitchenAid Blenders Experts
Appliance engineer
ThaMp3Doctor
ThaMp3Doctor
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
