Question about KitchenAid KSB580CR - 5 Speed Blender Custom Metallic Series, Chrome
Check the blade assembly if it is loose tighten it up. If it is worn out or cannot be tightened up then buy another jug complete with blade. If it is the glass jug model then the blade assembly is available without the jug and they also have a replaceable seal at the base.
Posted on Dec 19, 2013
SOURCE: Blades on inside of kitchenaid blender jar won't turn.
look on ebay for a replacement second hand unit
Posted on Nov 09, 2009
SOURCE: We own a kitchen aide
The Instruction & Recipe booklet for the Kitchen Aid KSB550, KSB560, KSB570, KSB580 5-speed Blender can be found here:
http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209709225.pdf
There is no infomration to suggest that the blender blade could be removed for replacement of a seal
On page 27 of the pdf (page 24 if printed) there is contact information for ordering replacement parts. You might ask if the blade assemly can be ordered and replaced separtely but I believe you must replace trhe blender jar and blade unit as one piece.
Posted on Mar 18, 2011
SOURCE: How do I fix or
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks.
Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it.
I hope this helps. If it does, please come back and rate my suggestion!
Posted on Jun 16, 2011
Apr 02, 2014 | KitchenAid 5-speed Blender With Glass...
Mar 07, 2014 | Oster 6700 Work Top Blender
Nov 28, 2013 | KitchenAid KSB560MC 5Speed Blender
Dec 07, 2012 | KitchenAid 5-speed Blender With Glass...
Jul 20, 2017 | Cuisinart SPB-7CH SmartPower 40-Ounce...
Apr 23, 2012 | Waring Pro SDM50 2-Speed Blender
Dec 20, 2010 | KitchenAid KSB560 5 Speed Blender
Mar 22, 2010 | Cuisinart BFP-703 SmartPower Work Top...
Nov 29, 2009 | Blendtec Extra Carafe / Jar for the Total...
Jun 16, 2008 | Back to Basics Blender Solution 5500...
387 people viewed this question
