Question about KitchenAid Blenders
My kitchenmaid pitcher is stuck on the mixer. it still mixes, it won;t detach
It still mixes, won't detach
Posted by Denise Jeong on
  • Denise Jeong
    Denise Jeong Aug 26, 2016
    one said put hot water, i can wet the mixer?
Ross Keen
  • KitchenAid Master
  • 1,364 Answers
The coupling on the motor has become bonded to the coupling on the beaker. Maybe it was moving about excessively and the 2 plastic parts have fused together. You can expect to have to replace the motor coupling and at the least the blade assembly or possibly the whole beaker depending on model. Knowing what you are up for needing to replace now if you wish to get it off put a litre of water in it, put the lid on and turn it on high and wobble, wriggle it about until it is able to be lifted off.
Posted on Aug 30, 2016
Base of my blender won't detach
please use the WD-40 for to loose and Ready.go www.40company.com
God bless you
Nov 06, 2013 | Cuisinart BFP-703CH SmartPower Duet...
How do i get the bottom off the blender jar?
The best way that I've found to remove the bottom from the blender jar is to put the blender jar back on the blender base (make sure it locks in place) and then turn the jar to the right. You'll feel the jar detaching from the base. Once it's loosened up, remove from the base and finish turning the bottom, manually. Before I found this method, I had tried everything to get the plastic bottom detached from the jar. Without removing the bottom, there's no way to clean it properly and rather than be unsafe I'd need to throw the whole works in the trash. But the method I've described above works every time!
Aug 13, 2011 | Jenn-Air JBL800 Work Top Blender
The chopping mechanism, which should turn freely, is "frozen" & won't turn. not even manually.
I'm assuming that this isn't happening on an model in which the bowl can be detached - otherwise the plastic bushing has melted and glued the shaft to the base of the mechanism - it will have to be replaced. You can find one on the Breville site
http://www.brevilleusa.com/blending.html
select yours and you will find it in the Parts &Accessories tab.
The mixer has an plastic bushing on the shaft of the chopping mechanism that is there to connect it to the shaft of the motor. If that bushing or the bearing of the shaft got damaged in any way the entire mechanism will lock out.
To find out what exactly happened you will need to dismantle the mixer - take out the 4 screws on the bottom, unclip the power wire, remove the supports of the motor and pull it out for inspection. Parts from older models can be obtained only from a dealer, you will have to contact one and order it .
Jul 30, 2011 | Breville Blenders
I inherited a hand-held blender; the stem is not detachable. How do I wash it?
Just blend warm water with a litle soap and then dry it with a dry cloath. Remeber to remove the socket when you dry it out for extra safety.
Aug 14, 2010 | Hamilton Beach 59735 Handheld Blender
V5785 mixing part broken (leaking)
I need the villaware smoothie maker top model V5785 as mine broke & can't find anywhere. Please help!
Apr 19, 2010 | VillaWare 4785 Smoothee Work Top Blender
A blade on my immersion blender was bent slightly. The motor still works and the blades spin, but they no longer emulsify. Can I buy just a new blade attachment?
If you have a model with the detachable blades. Otherwise, you'd need to purchase the blending rod from www.wpcookware.com.
Jan 16, 2010 | Wolfgang Puck Immersion Blender
I have a stick blender. How do I attach the flat
if the whisk attachment looks like the bottom part of your blender- the bottom part, with the blades, is probably detachable, and you can grasp it, and turn it counter-clockwise to detach it, and connect your other attachment by locking it in clockwise! just a guess!
i have one, but no added attachments-but can remove blade part to clean it- as i stated- just a guess!!
good luck!
Oct 09, 2009 | Blenders
Blender performes poorly, if at all
Hi, cauliflour is not compact no water mix, I have suggestion , cut it 1/2" long make it fine put in blender mix w/small amount of water then start. shut off mix with wooden mixer and start again then okey.
Jan 14, 2008 | KitchenAid KSB5 Professional Stainless...
Blenders Logo
447 people viewed this question
Top KitchenAid Blenders Experts
Appliance engineer
ThaMp3Doctor
ThaMp3Doctor
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
