Question about KitchenAid Blenders
Where is located the fuse on kitchenaid blender motor?
Posted by Ricardo Pianta on
magna buff
  • 3,828 Answers
Dont normally have a fuse
self insulated plugs for safety
fault is either the plug, motor or switch
with a continuity test light or meter
you need to check there is a constant circuit at the two plug prongs
Posted on May 27, 2016
Testimonial: "In fact, there is a thermal fuse hidden under a metal belt. I have found it and identified it was open. Replaced it and done!"
2 Related Answers
Anonymous
SOURCE: Blender died ...... motor won't turn on
It needs a new fuse (or atleast the worked for me)
Posted on Jul 09, 2010
Appliance engineer
  • 225 Answers
SOURCE: Need new glass container for kitchenaid blender.
They are usually in stock here:
http://kitchenaidblenders.co.uk/Home/tabid/36/c/KitchenAid-Blender-Spares/CategoryID/6/Default.aspx
Posted on Jan 24, 2010
The blender will not turn on, the lights for each selection blink on and off but the blender will not spin.
Remove the bottom cover 1nd unplug the motor from the PCB, check the motor for a circuit with your multi meter. If the circuit is open then remove the motor and locate the thermal fuse attached to one of the field windings under the metal tie and tape for insulation. Test the fuse for a circuit, if it is open then you have 3 options, replace the whole motor, replace the thermal fuse only (it will need to be aftermarket as KA only supply motors complete) or just bypass the faulty fuse.
Dec 25, 2014 | KitchenAid Blenders
Why is the unit not turning on?
Check the motor for continuity, it may be open circuit. If it is locate the thermal fuse covered with insulation tape on one of the field windings (where the metal clip is) Check that for continuity, if faulty bypass or replace it.
Jun 28, 2014 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Problem with soup mate,all lights flashing but nothing happening
If this is a Kitchen Aid blender with the flashing lights then you will need to remove the motor base cover and check the motor for a circuit. If it is open circuit then either replace the motor or locate the thermal fuse (under some white tape and aluminium clip on one of the field windings) and either replace or bypass fuse if it is open circuit.
May 19, 2014 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Blender won't start
Test motor for continuity, if open circuit locate thermal fuse in windings and replace it. If not open circuit check cable for continuity, if that is ok you are likely looking at a new button control assembly.
Mar 12, 2014 | KitchenAid Kitchen Aid KSB560 5 Speed...
Blinking lights blender
Probably open circuit motor. Locate and replace thermal fuse on motor windings or replace the motor. After you have proven the fault of course. Check with a meter.
Feb 01, 2014 | KitchenAid KSB560 5 Speed Blender
KitchenAid KSB560TG0 Blinking lights
Wont turn on,just blinking light
This will probably need either a new thermal fuse on the field windings or a new motor.
Nov 17, 2012 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
How do you replace a bad circuit in Kitchenaid blender KSB50B4
It is more likely the motor is faulty than the circuit board. Test the motor with a meter.
Aug 12, 2012 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Have you tried the fuse first....
If it is the motor (quite rare), these people may be able to order you one:
Aug 10, 2009 | KitchenAid KSB3 Classic Work Top Blender
KitchenAid Blender KSB5WH3 flashing lights how to get to the fuse
i found broken solder connections on triac on circuit board. it's the part with the cooling fingers that surround it. pencil soldered the cracked connections; now works fine.
Jun 19, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Blenders Logo
439 people viewed this question
Top KitchenAid Blenders Experts
Appliance engineer
ThaMp3Doctor
ThaMp3Doctor
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
