20 Most Recent KitchenAid Kitchen Aid Kitchenaid 5-speed Ultra Power Blender Blenders 5-Speed Blender Questions & Answers
Hiya,
Sorry to hear you are experiencing an issue with your blender. We believe that the described issue indicates control board fault.
If you have KSB555, please follow the link below to show you how to replace this part on your appliance.
https://www.kaparts.co.uk/Help/KitchenAidHelp/KitchenAidBlenderHelp/HowtochangetheControlBoardonaKSB555/tabid/650/Default.aspx
https://www.youtube.com/watch?v=Lafh8UGn4No
Hope you found this useful :-)
KitchenAid... | Answered on Sep 12, 2019
how to tighten nut on kitchen aid blender
Buy a new one
KitchenAid... | Answered on Sep 23, 2017
More often than not it will need the motor to be replaced, only Kitchen Aid parts will do, motors are usually unique to brands and models. Sometimes it can be the control/button panel but normally the motor.
KitchenAid... | Answered on Mar 10, 2017
From Kitchen Aid they only come on a new motor. I am a Kitchen Aid service agent and I remove them from burnt out motors and keep them. Look for a service agent near you and see if they can help you out. I have no idea where you are, I'm in New Zealand.
KitchenAid... | Answered on May 09, 2016
Magnet is not available as a separate part, you need to buy a new motor and be more careful in the future.
KitchenAid... | Answered on Apr 29, 2016
Blenders are not to be used for washing dishes, that may be where your problems are.
KitchenAid... | Answered on Aug 04, 2015
If this is a Kitchen Aid blender with the flashing lights then you will need to remove the motor base cover and check the motor for a circuit. If it is open circuit then either replace the motor or locate the thermal fuse (under some white tape and aluminium clip on one of the field windings) and either replace or bypass fuse if it is open circuit.
KitchenAid... | Answered on Dec 06, 2014
Check the motor for continuity, it may be open circuit. If it is locate the thermal fuse covered with insulation tape on one of the field windings (where the metal clip is) Check that for continuity, if faulty bypass or replace it.
KitchenAid... | Answered on Oct 04, 2014
There is no microwave hood on a Kitchen Aid blender
KitchenAid... | Answered on Sep 07, 2014
Try asking this in the dishwasher department, asking it in the blender dept will invite unhelpful replies like this 'cos I know nuthin' about dishwashers.
KitchenAid... | Answered on Jul 26, 2014
You could try asking this in the Tefal part of this forum instead of the Kitchen Aid area as folks who know Tefal may not be browsing this area. You could also be a little more specific about exactly what the fault is that needs repairing.
Kitchen Aid blenders are used for chopping/blending not heating.
KitchenAid... | Answered on Jul 23, 2014
Lever it off with a screwdriver, it is aluminium and the threads on the ring will break away. Pick them out of the thread on the motor shaft and screw on a new coupling, it will be left hand thread.
KitchenAid... | Answered on Jul 19, 2014
It is more likely the motor is faulty than the circuit board. Test the motor with a meter.
KitchenAid... | Answered on Dec 26, 2013
This will probably need either a new thermal fuse on the field windings or a new motor.
KitchenAid... | Answered on Dec 20, 2013
Assemble it with motor secure and base & feet on. Drill 3 or 4mm hole in edge of coupling Put screwdriver into hole on a large angle and whack the handle to undo the coupling. You are whacking it to turn in the same direction it turns when the motor is running.
KitchenAid... | Answered on Dec 05, 2013
KitchenAid Kitchen Aid Kitchenaid 5-speed Ultra Power Blender Blenders 5-Speed Blender Logo
77 questions posted
Top KitchenAid Blenders Experts
Appliance engineer
ThaMp3Doctor
ThaMp3Doctor
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
View Most Popular
KitchenAid Blenders
  • KitchenAid Blenders
Most Popular Question
kitchen aid 5 speed blender after
  • Blenders
