Question about KitchenAid Blenders
When the mixer is put on all the led lights flash but mixer would not start
Model no KSB1575MC Serial no W42252092
Posted by H A K Rao on
Ross Keen
  • KitchenAid Master
  • 1,364 Answers
Most likely the motor will be open circuit
Posted on Jul 07, 2016
My kitchenmaid pitcher is stuck on the mixer. it still mixes, it won;t detach
The coupling on the motor has become bonded to the coupling on the beaker. Maybe it was moving about excessively and the 2 plastic parts have fused together. You can expect to have to replace the motor coupling and at the least the blade assembly or possibly the whole beaker depending on model. Knowing what you are up for needing to replace now if you wish to get it off put a litre of water in it, put the lid on and turn it on high and wobble, wriggle it about until it is able to be lifted off.
Aug 26, 2016 | KitchenAid Blenders
I need the Manual Kitchenaid 600 mixer
Tip it upside down and read the proper model number then enter it into the box on this page at the Kitchen Aid web site
http://www.kitchenaid.com/customer-service/manuals/
Jul 24, 2014 | KitchenAid Professional 600 6 Qt. Stand...
Ticking sound in kitcheaid mixer
Remove the planetary and see if the noise vanishes, if not then you will need to open up the gearbox. It could be the pin retaining the fuse gear or maybe even the fuse gear itself failing. It seems unlikely though as you were only whipping cream and there is no effort in that.
Sep 03, 2012 | KitchenAid Professional 600 6 Qt. Stand...
Blender stopped working
Sounds like the motor burned out.
Jan 30, 2012 | Black & Decker Blenders
Have had my Vita-mix 5000 for several years with no problems. Now, it leaks oily, black liquid around the base, and jerks erratically when the blender is set on the lowest setting (#1 of 10)/variable.
Is it getting hot when you operate it? If you run a mixer for a long
time, the motor will get very warm. On the older units, when the
motor overheats, the various parts of the motor and its container
may start to melt. Mixer motors are not designed to last forever and
a replacement motor may be available from the manufacturer.
Another way is to purchase another similar mixer as you can on
eBay and swap parts.
Aug 21, 2011 | Vitamix 5000 Work Top Blender
I have a Vitamix Super 5000. I'm afraid I ruined the motor! I tried pie crust in it...the first batch turned out fine...the 2nd batch I started and the mixer turned off. Won't start. I was NOT using...
It's probably fine, those motors are very strong. I'd be looking for something like a wire off or broken first. A motor does not often fail without a lot of heat and burning smell.
Mar 03, 2018 | Vitamix Super 5000 Work Top Blender
Beaters
KitchenAid Turbo Beaters - Stainless Steel
Model: KHM2B
$14.99
Features:
Replacement or Extra Set of Self-Cleaning Stainless
Steel Beaters Mix Cookie Dough Easily.
Turbobeaters fit only Hand Mixers manufactured since
September 1997.
If you have a model produced before 1997 please call
the KitchenAid Customer Satisfaction Center at
1-800-541-6390 with the model and serial number from
your hand mixer for further assistance.
Mar 23, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Lights/LED lit up, but blender does not start!
The motor brushes may be in need of replacement.
Sep 09, 2017 | Cuisinart CB-600 Blender
Blenders Logo
318 people viewed this question
Top KitchenAid Blenders Experts
Appliance engineer
ThaMp3Doctor
ThaMp3Doctor
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
