I would clean the filter and let it dry completely for 24 hours. if you put the filter in wet and the run the vacuum the moisture well go in to the cyclone and the dirt would attach to it causing a snowball effect if you will, causing the vacuum to build up with debris and to smell. so clean out that filter really well and let it dry really well then try it out. if it still smells then i would replace the cyclone. they run anywhere around $80.
Empty it, clean it thoroughly and clean or preferably replace the filters.
