SOURCE: installing new ink cartridge, canon pixma 1600
Go here. Type "how to install ink" in the search box. Click "Search", then select "How do I install the ink cartridge(s)". You will get instructions with pictures on how to prepare and install the cartridges.
SOURCE: how do you refill an
its a very tricky thing to do and suggest you either take your empty cartridge to a professional or buy a new cartridge. do not attempt to do a diy job if u do not know what ur doing. the wrong mixture can have catostrophic events.
SOURCE: print heads pixma ip3500
The user manual for your Canon Pixma IP3500 is here:
http://www.retrevo.com/support/Canon-iP3500-Printers-manual/id/3124ci168/t/2/
Scroll down from the top of the page to where you see 'product support information'. There is a set-up guide as well as the user manual. The information you need should be there. Good luck!
SOURCE: waste ink absorber full
my printer is very broken in this so absorber full,it make reset manual,can helm me
SOURCE: The light for the magenta cartridge on my iP3500 printer goes off
The cartridge, as well as all ink jet cartridges has a chip inside that tells it how much ink is in the cartridge. Your cartridge is LYING, except it prevents you from printing without all cartridges working. ( same for my 6 color epson ). You need to replace the cartridge. I get my cartridges at a yahoo store called Inks4less. They have good quality for cheap.
There was a study done, analizing the amount of inks left in inkjet cartridges when they indicated empty, and the range was 7% to 25% ink still left.
How do you open the Canon Pixma MP520 printer so that you can see the print cartridges?
