Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum Logo
Posted on Feb 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The cable will not lock when extended on dyson dc05, Can I mend this by repairing cable reel or will I have to replace the whole unit.
Manchester Vacs
Level 2:
Filmmaker:
Uploaded 5 video answers.
  • Expert 107 Answers
  • Posted on Feb 13, 2011
Manchester Vacs
Expert
Level 2:
Filmmaker:
Answers
107
Questions
0
Helped
59841
Points
267
It will be much easier to replace the whole rewind unit. They are a pain to repair and there are many other things to go wrong with a worn one. Replace the unit.
Can you replace dyson on/off switch dc05 turbobrush
There are a number of places that list replacement switches. There are also a number of DC05 models, though the power switch is not likely to vary across them. Amazon, for instance, has a Dyson Switch for models including the DC05 and six other models (see here
Dyson Switch Dc03 Dc04 Dc05 Dc07 Dc08 Dc11 Dc14 On Off )
This video (ostensibly for a DC08, but the procedure should be pretty much identical) shows how to take the unit apart, get at and test the on/off switch, and replace it if need-be.
How To Change Dyson DC08 Switch An Easy To Follow Tutorial
Good Luck!
Will a dc05 retract unit fit a dc08
i'm not sure the dc08 looks slightly bigger , i'm sure if you phone Dyson up they will give you that information, here is a video of dc05 replacing cable rewind unit..
Dyson DC05 MotorHead schematic
Hi David,
Unfortunately the DC05's Motorhead is supplied as a complete assembly, so we're unable to offer individual components to repair your Motorhead. If you'd like to order a replacement Motorhead assembly, you can do so via our Helpline on 0800 298 0298, or through our online store:
http://www.dyson.co.uk/Spares/Variant-Spares.aspx?pid=DC05-Motorhead
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
1helpful
Product is actaully a Dyson DC05 Power lead has
Don't know product first hand but it should just hook back up and yes yu can dismantle it just keep it powered down while doing so (unplugged)
The cable needs changing looseconnection can not get into dyson
Hi its Darran at Dyson.
In the UK we offer a repair service for £69 which includes parts labour and VAT. If you would like to arrange this, please contact our Helpline on 0800 298 0298.
You can also purchase a replacement cable reel by calling us. Please ensure you have the serial number of your machine when calling.
Kind regards
Darran
Dyson Customer Service
My DC05 does not switch on. I have checked and confirmed the fuse is ok and washed & dried the filter
You can sometimes tell from the "feel" of the switch if this is a problem with the switch itself. However, by far the most common cause of the "won't switch on" problem is damage to the flex. Dysons are often let down by the quality of their flex, and it's quite common for the copper wire in the flex to break (compounded by the fact that the plastic tends to become brittle, especially if the flex has not always been fully unwound in use). This usually happens where the flex is subject to the greatest strain and bending - where it leaves the plug and at the other end which (sadly for a DC05) is inside the rewind reel. There may or may not be visible external signs of damage.
If you want to know what's involved in fitting a new flex and reel, go to www.dysonmedic.com then scroll to the bottom of the page and click on "DC02 cable replacement". The person who set up that site hasn't done a page for this job on a DC05, but the DC02 is similar. His "DC05 motor replacement" page shows you how to dismantle the 05 and get to the cable reel.
I hope this helps. Good luck!
5helpful
My dyson dc 05 cable retractor will not retract cable
Sounds like your cable reel mechanism is broken. Go to <a href="http://www.grosse.is-a-geek.com/diydc05mc.html">this link</a> to see a step-by-step guide for replacing the reel. You will need to order it from a spares provider. Google is your friend. Prices around £23.
HTH
What tool do I need to open a Dyson DC05??
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=34218&thid=542163
Posted by fixdaddy on Apr 24, 2008
I have a DC05 vacuum cleaner with a few minor problems which I am sure could
easily be fixed if I could open it up. The problem is that the fasteners
(presumably screw heads) are recessed so deeply in the plastic moldings
that I cannot reach them with any tools to find out whether I have the right
one.
Has anyone on this vacuum ever successfully serviced a DC05 to know what
tool is needed so I could buy one.
Thanks in advance
Steve Harvey
Steve Harvey at DSL dot pipex dot com
How to remove wheel to access cable storage area? Then ... How to replace electric cable.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I checked with some of my contacts in the vacuum business and they told me that it may not be a United States vacuum and it might be a Canadian or European vacuum and may not be customer friendly to service, if you have a contact with a MAC or Snap On dealer or a metric auto store – show them the screw and they might have something to fit or release the screw head, as per the removing of the wheel and replacing the electric cable, check with your local vac dealer or you may want to check with the Dyson dealer website and or phone # listed below:
http://www.dyson.com/homepage.asp
Contact Us
1-866-MY-DYSON
(1-866-693-9766)
Dyson Customer Care is available 7 days a week.
· Mon - Fri: 7am - 8pm, CST
· Saturday: 8am - 6pm, CST
· Sunday: 9am - 6pm, CST
[email protected]
Don – The Vac Man
Go Ahead. Use Us.
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
