AT&T 2256 Cordless Phone Logo
Posted on Dec 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Line is dead they told me to unplug everything for 15mins and put it back on still the line is dead
Anonymous
Level 2:
  • Expert 61 Answers
  • Posted on Dec 28, 2010
Anonymous
Expert
Level 2:
Answers
61
Questions
Helped
12417
Points
186
I would call att and tell them whats wrong
I took my car to a corner mechanic to put in a used starter. Next day the car dont start. Again battery dead. 15mins to jump. Dead again. At night l pull off the battery cable. I put it back the am.
Sounds like you have an electrical drain somewhere in the car.did you recently install a radio or other device such as an alarm.the circuit is probably draining overnight.also check that the battery terminals are clean and tightened down.
Well i accidentally pushed my earpiece into the USB and the computer suddenly shut down and wont on
Could be shorted. Try pulling all the cables out of your computer, those at the back. usb cords, power cords, baby jack. Leave it unplugged for 15mins and replug everything back. make sure you plug into it correctly
I'm only getting white screen with black,
You'll need to check all the connectors that you unplugged, make sure they are plugged in to the correct place, plugged in well and no pins bent over etc, Probably should also check any connectors that you did not have to unplug just to make sure they didn't get pulled while you were getting to the color wheel.
Whirlpool refrigerator model: ET8CHMXKQO 3 does not cool or freeze
unplug for 15mins after to remove the freezer to 3 feet from the wall. after those 15mins plug back
Refrigerator stopped working
unplug for 15mins , move your fridge to 3 feet from the wall clean the back and don't put anything in the back and plug back
Line in Use
I unplugged everything for 30 minutes. I guess everything needed to be reset.
1helpful
Fax problem
unplug the fax from the phone line. call it from you cell.if you hear your phones ringing in the house, plug the fax machine back into the jack. [you should still be on your cell phone] if the line goes dead or stops ringing, there is a short with the fax machine or wire to the jack.if you hear a busy signal without the fax plugged in, unplug everything you have plugged into phone jacks thruout the house. call your # again.if you hear ringing on your cell phone, plug everything back in one at a time.[again while still on your cell phone] if it was one of the phones plugged into a jack, when you plug the shorted phone back into the jack, the line will go dead again. that phone or cord is the problem.
if still rings busy when everything is unplugged, then call your phone company. it can be an inside wire or jack problem, or the problem is outside your home.
hope this helps
wg
3answers
Travelmate 2300 won't power on
The problem could be your bezel.  Remove the 3 screws from the hinges from the rear and you will be able to remove the black strip above the keyboard (after removing the screws, make sure laptop is layed wide open)  once removed, press the button on the motherboard under where the power button is.  If the unit still does not power up, then your motherboard is bad and needs to be replaced.  If it does power up, you need to replace the bezel.
Top AT&T Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
