SOURCE: acer PD113 DLP Projector
If you can work an the micro level of troubleshooting, have access to the the necessary instrumentation and tools, have the proper surface mount soldering station, test jigs, and also be able to have the access to the factory diagnostics software, and required replacement parts, then I would say you can troubleshoot and service this module. The factory service centers replaces this module. They don't spend the time and cost to service it at the component level. I have serviced some types of projection screen systems. They are very complex, and are normally serviced at the modular level. After replacement of some types of modules, some factory adjustments are required to match the new module, or parts. In the end you will have to send the unit out for factory service.
SOURCE: Changes colors
This is a DLP projection. may be that you have a defective color wheel motor or supply voltage to color wheel motor is out of range.
[email protected]
SOURCE: When I plug in the projector to the mains and to
Hi ;
SOURCE: Good Eve., I have a Toshiba
For sure the broken glass bring about the blurringg image as the LCD image is not being projected with clarity.
You will need to use gloves to carefully remove the broken glass, remove then without damaging of the lens and the lamp.
Reset with the correct type.
Please dont forget to vote this answer was helpful
Many thanks
