Samsung RS2630SH Side by Side Refrigerator Logo
Posted on Jul 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wont cool the doors get hot wont cool if i unplug it for about 5 hours it cools some then stops
Anonymous
Level 3:
President:
  • Master 2,468 Answers
  • Posted on Jul 26, 2010
Anonymous
Master
Level 3:
President:
Answers
2468
Questions
0
Helped
707745
Points
7484
Your defrost heating element isn't operating,its located on the freezer compattments rear wall behind an access panel,by unplugging it,it will defrost and again let cold air flow thru the entire units cavity including the refrigeratot
Anonymous
Level 1:
Champion:
  • Contributor 274 Answers
Anonymous
Contributor
Level 1:
Champion:
Answers
274
Questions
0
Helped
66988
Points
12
The reason the doors get hot is to defrost its ok.
Freezer stopped after power outage
If the sides are hot, look at the defrost timer. Sounds like it has stopped running with the defrost elements on. The compressor has a safety switch on it that opens either if the compressor gets too hot or if it pulls too much current when starting. If your power flickered a lot before coming back on, that triggered the safety switch. Now that it's running normally, I wouldn't worry. The defrost timer is your problem now.
Door hot
Totally normal. The condenser sends hot gas through the frame to stop the freezer door freezing to the frame. Check to see if you have a fan behind the condenser grill and make sure its running and clean
I have a MFI2568AEW not cooling. A door was left open a few hours. After closing it stop cooling. I unplugged it for a few hours then replug NO COOLING! . I saw on utube on the same scenario and he said...
the ptc overload on the compressors bad,unplug the unit,remove the ptc off the side of the compressor and purchase a new replacement and it will again cool,this part is what starts and operates the compressor
2answers
Haier model HRQ04WNAWW refrigerator. Stopped cooling suddenly. Compressor is hot, really hot, and doesn't make a sound. Light is still on inside of unit, so are getting power.
the compressor has an internal overlod inside of it after 115 degress it opens and wont start till it cools down below 115 unplug and try putting ice cubes on top of com pessor to cool it down otherwise it will take hours to cool off
Fridge and freezer not cooling. Hot air coming from front of fridge.( Overly Hot and has a smell of burning )
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
please rate my answer.
Power on Interior lights on refrigerator does not operate not cool
The interior lamps fail to light up as the swittch is faulty , so replace teh door switch if a contact cleaning wont help.
Now the cooling is related to many issues, so shut off fridge to allow time of 5 hours, The restart , if the fridge does not cool , the compressor , gas pressure is done and must be checked. If cooling is present then check if the auto defrost timer/thermostat is faulty as the fridge might stop cooling after 12 hours.
Not cooling proberly. Unpluged unit for 5
return air ducts are frozen and need to be defrosted. unplug unit and with doors open , introduce warm air from a blowdryer for a couple of hours , the ducts that are frozen are behind the rear panel on the rear wall of the freezer
Freezer works frige dont unplug for an hour then it works .
I would suggest check the coils to make sure they are clean . Also check the fan which cools the compressor to make sure it is working . When you unplug , it gives the compressor time to cool down a bit , but after it restarts , it will get hot again and stop cooling .
1helpful
Panasonic large screen Model # PT-61LCX65
Here is the proceedure to replace the lamp and reset the lamp hours.
Lamp Replacement Procedure:
1. Press the POWER button to turn off the power.
2. Wait for about 1 minute until the cooling fan stops.
Note:
The lamp cooling fan will continue to operate for about 1
minute after the power is turned off. Do not unplug the AC
Cord from the outlet until the fan has stopped. Avoid
interrupting the power by using circuit breakers or switchable
power strips.
3. After the cooling fan has stopped, unplug the AC Cord from
the outlet.
Note:
Please wait more than one hour before replacing the lamp.
[ Forced cooling function ]
If you need to replace the lamp more urgently:
- The Projection display has a forced cooling feature.
After the POWER button is turned OFF, and during the
first minute of the normal cooling fan operation, press
the VOLUME UP button on the unit and CH UP key on
the remote at the same time for more than 5 seconds.
The cooling fan operates for about 10 minutes. (LAMP
LED will flash 5 times every 5 second and POWER LED
will flash red for 10 minutes.)
4. Remove the Front Cover Unit from the latches.
5. Turn the Knob to the left.
6. Pull the Lamp Cover out.
7. Loosen the Screw on the Lamp. Then, pull the Lamp.
Note:
Because the Lamp may still be hot, use caution when
handling.
8. Install the new Lamp, and tighten the Screw.
9. Install the Lamp Cover, and turn the Knob to the right.
10. Install the Front Cover Unit.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
