Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
C
Chance Posted on Jul 10, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Freezer stopped after power outage
My model LFFU145HW 4 years old stopped freezing after a Power Failure, inside light out, but control panel is lit. Outlet has full power, and no breaker issue. Tried unplugging for 5 minutes, same result. Left it unplugged overnite, now it is running & cooling. Sides have always been hot to touch for years. Now cooling normally for past hour. I want to make sure it will continue until next power outage. What would you check or replace?
Lawrence Oravetz
Level 3:
  • Frigidaire Master 10,558 Answers
  • Posted on Jul 10, 2016
Lawrence Oravetz
Frigidaire Master
Level 3:
Answers
10558
Questions
Helped
2695783
Points
29284
If the sides are hot, look at the defrost timer. Sounds like it has stopped running with the defrost elements on. The compressor has a safety switch on it that opens either if the compressor gets too hot or if it pulls too much current when starting. If your power flickered a lot before coming back on, that triggered the safety switch. Now that it's running normally, I wouldn't worry. The defrost timer is your problem now.
Re lights lit on freezer
Red light lit on freezer means that is not reaches operating temperature.
Most often the old freezer has three indicator lights.
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees
- orange light : pressing the so-called SUPER-switch which means that the compressor is running continuously. The SUPER-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
In new freezer managed by the electronics, this function has a predetermined maximum duration, in order to protect the compressor, and can have different marketing names like "shopping".....
Dado
Have power but not freezing, cannot hear motor, recently had power outage
Hello max ryan,
I understand that you had a power outage and now that power was restored, you have power inside the appliance but the freezer is not freezing and you can't hear the motor running. I would double check the breakers and make sure that they are on. You can also check the Temperature Control and make sure that it is not in the OFF position. If these solutions do not work, I would call the manufacturer for more help.
-Best Regards-
Had a short power outage. Freezer stopped working; light and panel would come on but compressor would not work. Still under mfg warranty but Sears will not schedule a repair for 14 days. Unloaded the...
find another service agent that is authorized to carry out warranty repairs on your make of freezer and have it fixed
Sears is not the only authorized service agent in town
My Kenmore Upright Freezer Model 25326432100 flashed "ER."
My freezer was purchased in February, 2004. It is a self defrosting freezer but ice has started forming along the bottom shelf and back wall. Also, after cleaning the freezer the other day it has stopped clycing. The freezer will stop running only if I turn it down to the #1 setting and then it will not come back on. If I turn it up to a higher setting the compressor will not stop running. It ran for over 24 hours and would not cycle unless I turned it off or set it at the #1 setting. When I unplugged it and pulled it away from the wall, there was a green water spot the size of a dinner plate underneath the freezer. Help!! Very Unhappy this freezer is only 6 years old. S in Phila.
2answers
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
2answers
Kenmore upright freezer no digtal light no motor running
if it is an electronic control freezer then the electronic control sounds as though it has failed if there is no digital read out
Freezer wont freeze - digital display has no display at all -
Melanie--
Because this occurred as a result of a power outage, you need to check that the outlet is OK. Plug something in the outlet like a lamp and see that it works normally. If that is OK, check the display for a light bulb that is burned out--incandescant bulbs do that occasionally in a power outage. If it is an LCD or LED display, the power supply is bad on the display board. Is the motor humming and making normal noises?--and your freezer is just not cooling? If no motor noise, look for a reliable and trustworthy appliance repair person. If the damage is costly, try to pursue a claim with the power company.
Dave M
1helpful
POWER LIGHT FLASHES ON / OFF
You need to install or change the battery for the power out freezer alarm. Mine was just doing the same thing. I looked on the web for the answer and couldn't find it. Opened the door to look for the model number and there was the diagram for the light flashing codes. Mine's battery compartment is in the grill on the bottom (right below the door) on the left side. Takes a 9v battery. I had a power outage recently and it must have killed the battery after beeping for several hours.
2answers
Stopped running
try putting on fast freeze. if it starts up this means thermostat is faulty. get back to me if you want
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
