FixYa.com
Panasonic PT-61LCX65 61 in. Rear Projection HDTV Television
All Products > Panasonic > Projection Televisions
Problems with Panasonic PT-61LCX65 61 in. Rear Projection HDTV Television?
Troubleshooting and Support
Solved Problems for Panasonic PT-61LCX65 61 in. Rear Projection HDTV Television RSS Feed Post a New Problem
lamp replacement
How do I replace the lamp. No instructions came with the new lamp and none are in the manual. I apparently also need to...
3 Solutions
pt-61lcx65-red spots on screen
My tv has developed two red spots on the screen. They tend to be noticable on dark backgrounds. I am able to operate the...
3 Solutions
Panasonic large screen Model # PT-61LCX65
Could you please send me the directions on how to change the lamp and reset the lamp hours on my tv. Thank you, Don...
1 Solution
lamp reset
I need instuctions to reset timer for lamp apperently customer satisfaction is not in the deal when you buy the tv
1 Solution
Panosonic PT-61LCX65 wont turn on, no...
My Panosic PT-61LCX65 is having a problem turning on. It was running fine and then my wife said it just.. stopped. She...
1 Solution
Neon Pink outlines around bright images
I have had this pt-61lcx65 for a year this month. I turned it on one day last week and my son noticed all the neon...
4 Solutions
need assistance and the email you've been...
I have meandered through this site and found, I just need the email sent to me on how to replace the lamp and to reset...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Panasonic PT-61LCX65 61 in. Rear Projection HDTV Television RSS Feed Post a New Problem
spots on picture
started with green spot upper left picture now developed purple spot bottom left
Post a Solution
Air filter error message
I can not find the air filter on my tv, what do I need to do to take care of this error message. TV shuts off 1 min...
Post a Solution
Air Filter Cleaning
I have a 61" Panasonic TV. I keep getting the message "air filter cleaning needed" and the TV shuts off....
Post a Solution
LAMP HOURS
IS THERE ANY WAY WITH MY PANASONIC PT-61LCX65 TO CHECK HOW MANY LAMP HOURS THAT HAVE BEEN USED?
Post a Solution
showing red
tv shows red and pink and a bit darker not as bright. being told after reading and learning my self that is is the light...
Post a Solution
color
Within the last 2 days, the color of my tv is not right. I can go thru all the settings, get it close, but if i go to...
Post a Solution
PT-61LCX65 part number LSUQ0100 jig
Hi, I am having a difficult time ordering this part. I've contact parts/tech/concierge and they have told me I need a...
Post a Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Screen Size61 inch
Display Format1080i (HDTV) · 480p (EDTV) · 720p (HDTV)
Digital TV StandardHDTV
Projector TechnologyLCD
Display Capabilities
Aspect Ratio16:9 · 4:3 Enhanced
Built-in TunerNTSC · ATSC
Remote Control
Remote ControlUniversal
Illuminated RemoteIlluminated
Image Quality
Comb Filter3DYC / 3D Digital
Audio Features
Audio TypeVirtual Surround
Sound LevelerWith Audio Leveler
MTS StereoSAP / MTS Stereo
Secondary Audio Programming (SAP)With SAP
Technical Features
Picture in PictureWith PIP
Parental ControlV-Chip
Sleep TimerWith Sleep Timer
Connectors
Rear Input ConnectorsS-Video x 2 · Audio (RCA) x 2 · Composite x 2
Front Input ConnectorsComposite x 1 · Audio (RCA) x 1 · S-Video x 1 · D-Sub (RGB PC) x 1
Memory Card SlotSD Card
Screen Text
OSD LanguagesEnglish · French · Spanish
Channel LabelsWith Channel Labels
Speakers
Number of Speakers4 Speakers
Dimensions
Depth40.51 in.
Height18.43 in.
Width56.06 in.
Weight101.4 lb.
Panasonic Contact Information
Main support number800-211-PANA
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
