Remove any paper trays. Inspect them for wrinkled or damaged paper.
Also open the back cover of the printer if this model has one.
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
If you find a piece of jammed paper, remove it by
holding it with both hands and pulling firmly. The goal is to keep the
paper from tearing. If several pieces are jammed together, try pulling
out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do
this step especially if the jam message comes up repeatedly without any
obvious paper jam, there may be a small tear of paper inside.
Ones the printer is free of paper Replace the toner or
ink cartridge and paper trays, close any doors you opened and turn the
printer back on.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
see alternative if the problem is still not solved.
alternative :
Load
a piece of thick paper, for example photo paper and press the resume
button (may be diffrent button on diffrent models) a few times to the
printer picks up the paper and puts it through the machine.
if the problem remains, some of the sensor / switches might have become stuck or are out of place, or there is still a small piece of paper or something else inside the machine and its coming up as a paper jam.
The machine would need to be taken apart and cleaned to solve the issue.
Was this helpful?
Yes
No
Popular Solutions for Dell Photo All in One Printer
on my dell photo964, the receive times that it will receive faxes keep changing. is there an...
(More)
on my dell photo964, the receive times that it will receive faxes keep changing. is there an internal battery that needs replaced?
dell aio 966 wont print says enable bi directional support but when i go to tick the box its ghosted...
(More)
DELL AIO 966 WONT PRINT SAYS ENABLE BI DIRECTIONAL SUPPORT BUT WHEN I GO TO TICK THE BOX ITS GHOSTED OUT SO CANT TICK IT
I cannot print business cards on my dell photo all in one printer 964. I am using avery heavyweight...
(More)
I cannot print business cards on my dell photo all in one printer 964. I am using avery heavyweight cards.
I have a Dell All in One 964 printer. I recently replaced the black ink cartridge with a new series...
(More)
I have a Dell All in One 964 printer. I recently replaced the black ink cartridge with a new series 5. All was good for several weeks then one day I received a message on the printer indicating that the "left cartridge is missing" and the computer is saying that "a non-compatible cartridge is installed". I have tried numerous times to get help from Dell and have met with no success.
