20 Most Recent Samsung SCX4623F Laser All-in-One Printer Questions & Answers
Recommend contacting Samsung directly for assistance:
Contact Us
Samsung SCX4623F... | Answered on Feb 07, 2018
The communication between the computer and the printer have disconnected. Do a reset of the printer. Rest the parameters, like the IP Address, Pass Codes, etc.
Check you DEVICES (Printers) to see if it is sending a Wi-Fi signal?
Samsung SCX4623F... | Answered on Jan 31, 2018
You are most likely getting this message because of a paper size mis-match. For example, you are sending a print job as letter size but your printer is set to or has a4 size installed. When the printer sees that the print job is not a matched size to the paper in the tray, it will look to the manual feed tray for paper to print on, hopefully the correct size. Make sure your paper setting in printer properties on your computer match the paper in the printer and the print job "page setup" is also the same size/
Samsung SCX4623F... | Answered on Dec 03, 2017
What are the steps to remove the fuser? I have not been able to figure it out. Unless you disassemble the entire unit. Thanks
Samsung SCX4623F... | Answered on Jun 18, 2017
  1. Prepare a new cartridge of the color (K, C, M or Y) you wish to replace.
  2. Ensure that the printer is on with all covers closed, and that the Toner Low warning, Sleep, or Ready status is displayed.
  3. Press the right%20arrow%20black.jpg Right arrow button to display the menu.
  4. Press the up%20arrow%20black.jpg Up or down%20arrow%20black.jpg Down arrow button to scroll through the options until Reset Menu is highlighted:
  5. Press the right%20arrow%20black.jpg Right arrow button once, this will enter the reset menu as shown below:
  6. Press the up%20arrow%20black.jpg Up or down%20arrow%20black.jpg Down arrow button to scroll through the options until Change Toner X (where X is K, C, M or Y) is highlighted for the toner you wish to change:
  7. Press the Right arrow button to start the removal procedure. The printers panel will read Please wait, then after a short delay the printer should display a red error light and the message Replace Toner X, where X is the relevant toner cartridge:
  8. Open cover D.
  9. Hold the toner cartridge knob and tilt it toward you.
  10. Remove the empty toner cartridge from the printer.
  11. Take the protective materials off of the new cartridge, and gently shake the new toner cartridge a few times.
  12. Take the new toner cartridge out of its package, and remove the plastic protective cover from the toner cartridge.
  13. Insert the new cartridge into the printer.
  14. Close the toner cartridge cover.
  15. Close cover D.
  16. If you need to change another toner cartridge, repeat the above procedure from Step 1.
TO view pics of the steps click here
Samsung SCX4623F... | Answered on Sep 10, 2016
door sensor lever disengage , pls check
Samsung SCX4623F... | Answered on Aug 13, 2015
Dear
You can try to upload the higher version firmware, some times it may revive the main PBA. The alternate is to replace the main PBA. But if some professionals are doing chip level repair and programming then you may take their help to restore the main pba.
Thanks.
Samsung SCX4623F... | Answered on Mar 08, 2015
Dear
You can use the ADF to scan the size documents.
Thanks.
Samsung SCX4623F... | Answered on Mar 04, 2015
Dear
Its related to the fuser assy. Pl. check the fuser thermostat and heating lamp. for if its open replace it, check the thermistor resistance if it open replace it, Check SMPS.
Thanks.
Samsung SCX4623F... | Answered on Mar 03, 2015
Dear
The toner cart. has lapsed its life.
As there is a chip inside cart. which keeps record of the page count and toner percent used. when predefined percent consumed it indicates.
The replacement with new cart or replacement of the chip and toner powder resolve your problem.
Thanks.
Hi there and welcome to fixya,
What's the model code for your printer?
There are three options;
XAX, XAA, XBG
For a direct link to the XAA type, follow the link below:
http://www.samsung.com/us/support/downloads/SCX-4623F/XAA
otherwise, you'll need to select the correct model code on the drop down.
On the Driver tab. Download the driver file under LINUX.
Hope this helps.
levbit
Samsung SCX4623F... | Answered on Feb 02, 2015
Just buy the reset chip!
Samsung SCX4623F... | Answered on Nov 11, 2014
it sounds to me that your paper size is not correct so it is tring to pick from the bypass. put paper in the bypass until that job is over or delete that print job. make sure your paper cassette is set to the right paper size. most of the time this problem comes up when rinting pdf files or from the internet.
Samsung SCX4623F... | Answered on Oct 23, 2014
it could be the silver bar under the glass that needs lubrication. this will cause it to say scanner lock. this is no fun to get to you should take it to a dealer for this.
Samsung SCX4623F... | Answered on Oct 06, 2014
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
Samsung SCX4623F... | Answered on Jul 07, 2014
Can you see the left side the small glass? that is where your scanner will scan from if you feed through the feeder on top. So inspect if there is some dirt on this if you find anything on that do clean it and this will solve the problem. The other problem could be with the cable connected to the assy. but for now you can try cleaning it.
DO RATE MY SOLUTION
Samsung SCX4623F... | Answered on Jun 16, 2014
Samsung SCX4623F Laser All-in-One Printer Logo
170 questions posted
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
jasbo
jasbo
Steve Allison
Steve Allison
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
SCX Samsung
  • SCX Samsung
Most Popular Question
got 02 000 error
  • Office Equipment & Supplies
