20 Most Recent Dell AllinOne Multifunctional (v515w) InkJet Printer Questions & Answers
It may have a date code ill not allow you to print without updating/replacing the cartridge. I got rid of hy HP for the same reason.
Dell AllinOne... | Answered on Jun 03, 2017
Did you use a brandname ink cartridge - or is it a knock-off brand? If it is a brand name - then the cartridge is most likely defective. If it is a knock-off brand - some printers do not recognize the electronic in the cartridge and therefore don't see it as one being installed.
This may also help
Dell 922 AIO Black Ink Cartridge Missing Message
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_e7c2c48c6e65f808
Dell AllinOne... | Answered on May 02, 2017
I have a Dell v515 on Windows 7 64bit. I just figured out how to bypass the printer chip counter. Start --> Control Panel --> Devices and Printers. Right click on your printer, choose Printer Properties. Go to the Advanced tab and click the Print Processor button. Choose winprint for the print processor and NT EMF1.006 for the default data type (I found this choice has the best print results). This does not reset the chip, but just allows print jobs to be sent to the printer without having to go through the Dell software. I am not sure how this works with scanning or copying. My guess is that there may be times that you have to change back to the original Dell print processor and LEMF for the default data type. Hopefully this works for anyone reading this. Good luck!
Dell AllinOne... | Answered on Feb 26, 2015
Not sure what code you are talking about. You need to use a cable and the install disk to set this up. Then you are prompted to switch to wireless.
Dell AllinOne... | Answered on Mar 02, 2014
Try to see if your mechine has a paper eject button, to Unjam ..try to see if you can still feed paper to push out the jamed paper...
Dell AllinOne... | Answered on Oct 02, 2012
The printer's IP address most likely needs to be changed.
Check the Belkin's IP address range (it maybe 192.168.2.***) and configure the printer's IP address accordingly.
Dell AllinOne... | Answered on Jul 15, 2012
Please follow the following steps.
1) Turn off the printer.
2) Shutdown the PC to which the printer is connected.
3) Remove the USB/Serial cable through which the printer is connected to the PC and reconnect it back.
4) Now switch ON the PC(only PC and not the printer)
5) Let the PC boot up and login to windows.
6) Now switch on the printer, PC should detect the printer automatically now.
Now you will be able to print.
Dell AllinOne... | Answered on Feb 14, 2012
Dell AllinOne Multifunctional (v515w) InkJet Printer Logo
Popular Tags
72 questions posted
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Office Equipment & Supplies
Most Popular Question
bypass printer ink chip in dell 515
  • Office Equipment & Supplies
