Canon PIXMA iP3000 InkJet Photo Printer Logo
Anonymous Posted on Sep 15, 2009
Color on photos suddenly has a blue - purple wash with no greens
I was printing photos using picassa 3 and the colors were perfect. The cartridges were low so I changed the cyan, magenta and yellow cartridges. Thereafter, the photos did not have any green color and had a blue purple wash color. I removed and reinserted the cartridges, I reset the default under printers and faxes and nothing changes the problem. I even reprinted the previous pictures that earlier came out perfect and they now have the same problem. So the problem is not the digital images. HELP!!
Adnan Bhatti
Level 3:
President:
  • Master 1,188 Answers
  • Posted on Sep 15, 2009
Adnan Bhatti
Master
Level 3:
President:
Answers
1188
Questions
Helped
410299
Points
3822
Your yellow cartridge is probably not working as your photos suggest. Remove and reinsert the yellow cartridge. Try printing only yellow color.
Your printer has a separate head for printing; the nozzle for yellow ink might be clogged. Try running a head cleaning routine from your printer software.
Testimonial: "Thank you so much. I tried what you suggested and it worked. Brilliant."
4answers
When printing, if I select any other form of paper than "Plain Paper", e.g. "Photo Glossy Paper", the print (of a photo) comes out with a distinct Magenta overhue. The true colours are...
Hello Landscapeman ,
You need to specify the paper type when the print dialog box appears. Heavy glossy paper needs to spend more time in the fuser so that the toner is fixed.
2answers
Colour prints coming out with a lilac hue
check whether the printer is in proper mode or not
Colors are off. Browns print green or purple. I
BROWN is made by mixing two of the three "primary" colours.
So, if the printer is out of RED ink, you'll get the "other" primary colour.
Print a "test" page, and verify that part of that page is RED.
Run a printer "cleaning" cycle, and consider replacing the RED cartridge.
Printer is printing wrong colors
Make sure it's the right ink cartridge for that model printer.
Check if any of the colors is out
Try running a calibration on the printer to make sure heads are lined up properly.
Link to the manual - Aligning print cartridges is on Page 70.
http://h10032.www1.hp.com/ctg/Manual/c00905552.pdf
Wont print colors correctly
Try replacing your red cartridge as it may be dry.
New tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
All of a sudden my printer just started printing in blue
one color of your cartridge were finished, replace/refill the cartridge again
2answers
Blue tint suddenly appearing on all my photos
you may need to run a clean on ur nozzles and check if you are low on ink.
1helpful
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
old marine
old marine
ZJ Limited
ZJ Limited
