20 Most Recent HP Deskjet 5440 InkJet Photo Printer Questions & Answers
Are you able to check with a volt meter there is power from output to printer.. No reading, best renew power supply
HP Deskjet 5440... | Answered on Jan 27, 2013
  • Turn off the printer and the computer.
  • Disconnect them completely from power.
  • Reconnect them after a while.
  • Check the print job now.
Hope it helps.Thank you!
HP Deskjet 5440... | Answered on Sep 29, 2011
You can download drivers for your printer on Hp's website located at www.hp.com. Click on support and then downloads and follow the prompts. Good luck!
HP Deskjet 5440... | Answered on Sep 22, 2011
Try using the HP Print Diagnostic Utility in Windows.
If you need more help post back!
Thumbs and testimonial are welcome!
HP Deskjet 5440... | Answered on Aug 03, 2011
Hi there, You will need to install HP Solution Centre from your CD that you got with the Printer. That is the only way you can see ink levels. Below is a guide on how to install it from the CD. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02463264&lc=en&cc=us&dlc=en&product=445441#N741
Or you could try this option. Just download and install. http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-90246-5&cc=us&dlc=en&lc=en&os=4062&product=445441&sw_lang=
Regards,
HP Deskjet 5440... | Answered on Jul 27, 2011
go to the control pannel
click to the add / remove programme
remove all programmes off HP printer one by one
HP Deskjet 5440... | Answered on Apr 30, 2011
hi there!
just push the power button to restart its print job, if that dont work, ive posted the link for that printer here, check out the manuals and troubleshooting steps too, they're all for free. you can also contact 800-HP invent or 800-474-6836.
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=445441
HP Deskjet 5440... | Answered on Apr 07, 2011
First, try pushing the arrow to allow the machine to clear out the command that it is trying to share with you. Then unplug the machine from the wall and the pc and wait 1 - 2 minutes. Plug it back into the pc first and then turn the pc on and allow it to go through its start up and load windows. When its finished, plug the printer back into the wall and then turn the printer on.
That should clear the error.
If for chance it does not fix this error and the light is still blinking you have two options. If the printer is still young enough to be under warranty then contact HP and have it repaired. they will give you an RMA number and have you mail it to them with a prepaid label or give you a local address to an authorized repair center.
If it is not under warranty and you do not have the money to repair it or feel it would not be worth spending money on to repair it - then here is my last suggestion:
The Printer has a motherboard inside with a Nicad battery which is flat and round. Usually the motherboard is located on the right hand side (if facing the printer in front of you). If you can pop that battery out, wait a few minutes and then put it back in - this will reset the printer and should clear the error.
I am not suggesting to ignore any problems that your printer may be reporting to you with that blinking light and if you choose to by pass it by using this option, please do so on your own choice.
HP Deskjet 5440... | Answered on Mar 20, 2011
Unplug the power and replug it .
Make sure you removed the protection tape from the cartridge.
Try pressing the down arrow button and see if the error goes away.
In vista right click the printer and select the option Use printer online.
If you need anymore help please let us know.
Rate the answer if it helped.
Thanks
HP Deskjet 5440... | Answered on Mar 10, 2011
HP Deskjet 5440 InkJet Photo Printer Logo
Popular Tags
136 questions posted
Clive
Clive
Thomas F. Schneider
View Most Popular
DeskJet HP
  • DeskJet HP
Most Popular Question
when print pen
  • Office Equipment & Supplies
