20 Most Recent
HP DeskJet 960c InkJet Printer Questions & Answers
Ink light is on. which cartridge needs to be replaced
The printer's indicator lights tell you when to obtain a replacement ink cartridge by flashing when ink is low, and when to replace an empty ink cartridge by remaining on when ink is depleted. The LCD panel also displays INK LOW or INK OUT.
Even if only one ink cartridge is empty, the printer cannot continue to print.
Prints greyscale only
Wonderful.Share a website with you ,( http://www.shoes2.us// )Believe you will love it.We accept any form of payment.http://www.shoes2.us/Michael-Kors-Handbags-n2447/
My HP 960c won't stop printing. I get mostly blank sheets with jibberish at the top, but it's continuous.
Turn off the printer. On the computer in the lower right by the time, there should be a printer icon, double click it. This will open the print que. Select all documents in the printer que and delete or cancle them. You may have to reboot the computer for this to clear completely. Once the que is clear, turn the printer back on. Do a test print to the printer and see if the issue is cleared up. If not you may need to reload your print drivers.
Hope this helps you
Colour cartridge prints in b&w only
Please follow the following steps.
1) Turn off the printer.2) Shutdown the PC to which the printer is connected.3) Remove the USB/Serial cable through which the printer is
connected to the PC and reconnect it back.Now replace the color cartridge with a new one.
4) Now switch ON the PC(only PC and not the printer)5) Let the PC boot up and login to windows.6) Now switch on the printer, PC should detect the printer
automatically now.
I have replaced black ink on a hp deskjet 960c and
I see you replaced the Black in on your HP printer but the light keeps on blinking still.
Make sure that you remove the silicon film from the ink cartridge before installing in the printer, if that file is not removed the contact to the printers ink will not detect the ink cartridge at all.
Also try to remove all the ink cartridges and install all of them at the same time , this is to reset the printer from detecting all the printer ink cartridges.
I hope this helps
I put new print cartridges
I have an HP DeskJet 1220C that has been working fine for two years
now. All of a sudden it can only print in pink and black. It is driving
me crazy. I have tried the following without any success:
1. Replaced the cartridges twice
2. Aligned and cleaned the cartridge from the
computer
3. Soaked the cartridge head in hot water,
and made sure that all three colors will bleed
out of the head
4. Cleaned the cartridge contacts with an eraser
5. Cleaned the cartridge contacts on the printer
with a brush
Is there a cure, or is it time for a new printer?
