Use the keyed red wire from the back of your unit(this means when the car is on, so is the amp) or use a switch to power it on and off(i don't recomend this because you can accidentally leave it on alllll night long. but it is a solution. If you're radio remote wire went out, check it as soon as it comes out of the unit to see if you have power there, maybe it's cut somewhere along the way. good luck
Anytime a door opens and/or closes randomly or doesn't work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ?½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone
remote wire, not sure what u refer to?
