Car Audio & Video Logo
Belinda du Preez Posted on Oct 04, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My JVC KD-R426 keeps on saying warning check wiring and reset system. I've tried everthing but it still does the same. What must I do
We were told to press the reset button 3 times - this does not work. I've also disconnected the unit and placed it into another car - it still does the same
  • 2 more comments
  • Anonymous Mar 22, 2014
    then reset problem
  • Nethaji Ravichandran
    Nethaji Ravichandran Apr 30, 2019
    Hello sir, I have jvc kw av70bt model. It's touch display model I got error "check wiring" what I want to do now
  • Matthew Stonecipher
    Matthew Stonecipher Aug 02, 2020
    Do you know how to get jvc kw-v830bt out of safe mode?
  • Syed Kaif
    Syed Kaif Dec 04, 2020
    Then reset problem
Josh Park
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 06, 2016
Josh Park
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
25117
Points
14
Not sure if this will help any other owners since my answer is 4 years late, but this is what I found from another user. Apparently if you mess with the wiring too often, it goes in a safe mode which you need to do some button trickery to unlock the device from it's safe mode. These are the Steps.
1.Disconnect power supply
2.Press [MENU] and [UP arrow] buttons and keep holding.
3. While holding the buttons [MENU] / [UP arrow], connect the power plug again
A. The display will show "DC ERR"
*** if it still shows "Chk wiring ..." repeat the steps above until you get "DC ERR."
4. Press [UP arrow]; the display shows "DC1 ERR"
a. Press and hold [UP arrow] and it will show "DC1 OK"
5. Press [Down arrow], the screen will show "DC2"
a. Press and hold [DOWN arrow] and the display will show "DC2 0"
6. Disconnect the power from the back of the unit.
7. Remove the Face Unit.
8. Reconnect the power from the back.
9. Use a sharp object and press the [RESET] hole for 3 seconds and release.
10. Reinstall the face unit and turn on the power.
  • 11 more comments
  • Kristen Stevener
    Kristen Stevener Jul 01, 2016
    Thank you. This totally did the trick.
  • Terri Charpentier
    Terri Charpentier Feb 10, 2017
    trying this today - thank you ---so far nothing else has worked
  • Shyjith Apr 22, 2017
    Corr. Its. Working......... ths.... sir
  • Sabrina markham Apr 22, 2017
    Thank you so much! I used this today, I don't even know if mine was the correct model lol but it worked!
  • Jojo Humphrey
    Jojo Humphrey May 25, 2017
    So it almost worked for me when i press the down botton it says DC4 instead of 2 but when i hold it down it does go to 0 but rite after it goes to the warning again
  • Tracy Spaulding
    Tracy Spaulding Jul 19, 2017
    THANK YOU!!! too many hours to admit to on this, this thread was my last effort for a resolve before I bought new!!! Very appreciated, it worked!!
  • Turlough
    Turlough Nov 11, 2017
    It worked for me thank you very much.
    Matthew Stonecipher Sep 02, 2019
    Thank you so much! After 2 years of not having radio i tried this and it worked! Did it ever pop up with the message again after doing this?
  • Paule Sirealone
    Paule Sirealone Jun 24, 2020
    Different model of JVC, your solution worked though! I was close to binning it...!
    THANK YOU!
  • Biwa 46
    Biwa 46 Sep 13, 2020
    IT WORKS JVC KD-R541
  • Hamza Gaci
    Hamza Gaci Jan 13, 2022
    Thank you so much for the solution ??
Anonymous
Level 1:
New Friend:
  • Posted on Aug 11, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
25117
Points
9
I am engneer i hav also check all wiring it is internly problem it is pcb fault (check wiring then reset) in jvc usb car cd
kenw392
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • JVC Master 2,226 Answers
  • Posted on Oct 12, 2012
kenw392
JVC Master
Level 3:
Renaissance:
Answers
2226
Questions
Helped
467802
Points
4986
It sounds like the internal output IC is bad. It would need to be replace.
5 Related Answers
Anonymous
  • 55 Answers
  • Posted on Aug 30, 2008
SOURCE: JVC head unit problem
Do you have a "RESET" button on your stereo? Check your owner's manual to find it. I have a JVC unit in my car and the reset button is a small hole behind the detachable face. Take the end of a pencil or a pen and insert it in the tiny hole and hold for a few seconds. This should reset the stereo so you can get the CD out. Hope this helps...
Anonymous
  • Posted on Feb 07, 2011
SOURCE: JVC KD-R610 is stuck in Protect mode
Try disconnecting your battery, reconnecting it, and resetting your stereo. If that doesn't work, the constant power (yellow wire) or ignition wire (red wire) may have come in contact with ground or isn't properly connected. Make sure everything is connected properly and try resetting your stereo. If it is still flashing "protect", the unit needs servicing Contact JVC Customer Care Center at: 800-252-5722.
kenw392
kenw392
  • 2226 Answers
  • Posted on Jun 06, 2011
SOURCE: I've installed my JVC KD-S17
Do you have power going to the red wire?
Anonymous
  • Posted on Mar 02, 2009
SOURCE: jvc kd-pdr30 ipod problems
The Touch will not work with the KDPDR30. I spoke with JVC and their models that will operate the Touch are KDPDR40, KDAPD49, KDPDR45, KDPDR41 and KDG47 the last two have a cable required.
Anonymous
  • 8 Answers
  • Posted on Jun 10, 2009
SOURCE: JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Reset button in kd-r426 and how reset
To reset your KD-R426, locate the reset button on the unit. This is usually located behind the faceplate. Once you've found the reset button, press and hold it for about five seconds. After a few seconds, you should see the message "RESET" appear on the display of your stereo. At this point, you can release the reset button.Your KD-R426 should now be reset and working properly. If you have any questions, or if you need help resetting your stereo, please consult your owner's manual or contact a qualified technician
I have a jvc kd-r45 it keeps on saying warning unit check wiring then reset
The check wiring message suggests a short probably in a speaker wire. Check that the terminal leads for the speakers are properly covered in insulating tape. Check the rest of your wiring, if you can, to check for any section where the insulation is worn and could come into contact with anything. Next remove the faceplate and use a pen to press and hold the reset button. The button is near the bottom of the middle of the receiver.
If the error persists, then another section of the wiring is making metal on metal contact with the car or another wire. You should contact a JVC dealer or the company that provided the kit with the KD-R45.
I hope this helps.
2answers
JVC miswiring no Sele quita ya le quit? el ic de salida lo reinicio el est?reo es JVC kw-R910BT si alguien a solucionarlo gracias
Jvc Manuals
The wiring diagram is on the last page of the manual at http://www.jvc.co.nz/assets/pdf-manual/KD-R526.pdf
1helpful
Jvc Instruction Manuals
The wiring diagram is on the final page of the manual at http://www.jvc.co.nz/assets/pdf-manual/KD-R526.pdf
2answers
I have a jvc kd-r311 radio in my car which has been working for about a year now, but a few days ago it came up saying "protect" on the front and now doesn't work, I've tried pushing the...
If you have a multimeter, try checking the speakers and speaker wires for shorts and/or grounds. Make sure your speaker wire has no bares spots. If the speakers and speaker wires all check out good, you may have a bad internal output ic.
I've been trying to download a user manual for a JVC KD-LH401 car stereo but all I've found are Greek and Russian ones, help!
  • Here is the users manual you are seeking in English free of charge.
  • Hope this helps and thank you for choosing FixYa.
Regards, Tony
4helpful
3answers
Top JVC Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Marvin
Marvin
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
