Question about Vehicle Parts & Accessories
Excalibur alarm I unlocked my car manually with my remote and the alarm went off of course, when I pressed the unlock button it went off. then I stuck my key into the ignition and it starts going off, what now?
Posted by annie terberg on
rtb143
    New Friend:
  • 10 Answers
The valet button is on the antenna ignition on hold the valet switch for 2 seconds. Light on the antenna will remain solid. Your now in valet modE and the alarm will not arm anymore. U can also try to reprogram the remote.to do this ignition on press valet switch 5 times then press lock on the remote . Ignition off now the remote is programed.
Posted on Feb 05, 2015
Aries
    Sergeant:
  • 206 Answers
Hi
when you press the off button you have to remove the plastic cover under the steering wheel
remove the fuse from the red wire which is the power wire to the alarm
this will disable the alarm but you will be able to use your car
aries
Posted on Oct 19, 2013
5 Related Answers
insanegtp
Keith Methot
  • 112 Answers
SOURCE: i cant cut off my alarm and car wont start
is ti and aftermarket or factory system, if aftermarket look for little black button under dash or button on antenna, turn key on and press for one full second, if aftermarket unlock door with either trunk or passenger side and try again...
Posted on Jan 26, 2009
Neville Hayes
  • 22 Answers
SOURCE: Disalarmed - cannot now reset, no alarm
Drop down the dash and locate the alarm module(generally a black box) find two thicker wires going to or from the ignition. at the ignition end check to see if these two wires are attatched to a wire coming from the ignition that has been cut and joined to the two alarm wires ,if so cut them and rejoin them,this will get you home.Then go to a tech.
Posted on Apr 21, 2009
Anonymous
  • 47 Answers
SOURCE: Disable or disconnect the factory installed alarm
should be a fuse for it, just remove it......
Posted on Jul 07, 2009
Anonymous
  • 53 Answers
SOURCE: I have the Python 872 Alarm on my 95 Acura Integra
to disable the alarm, you would 1st need to know where the valet button is. It is usually underneath the dash. What you do is u open the door and of course the alarm is going to be set off you quickly turn the key to the on position and press the button once and then wait, then the alarm should shut off and now you can start your vehicle. Thats the standard procedure for the DEI alarms. For some reason it doesnt disable it then your other option would be finding the alarm brain and pulling out both fuses. One is for the lights and other is for the main power to the brain, i say pull both to make sure you have successfully killed the power to the alarm
Posted on Jul 16, 2009
Jason Ewing
  • 103 Answers
SOURCE: VIPER CE0890 My alarm started going
Turn ignition to the ON position, press and hold the valet switch under the dash. It should turn the LED light on solid
Posted on Aug 21, 2010
I just bought a 2001 Subaru Forester, I put the key in the door lock to unlock the door and the alarm went off and won't stop. How do I turn the alarm off?
I would try to close the door and press the unlock button on the kay fob. (If it has a remote intergrated with the key). This should unlock the door and turn off any anti-theft devices.
Jul 27, 2012 | Car Audio & Video
Tip
How to Program Acura Remote Transmitter
Acura Remote Alarm / Central locking
Model: CL Year: 2001-2003
Model: TL Year: 1998-2006
Model: MDX Year: 2001-2006
Model: RDX Year: 2007-2009
Model: RL Year: 1996-2004
Model: RSX Year: 2002-2007
Model: TSX Year:2004-2008
System Operation
  • Pressing remote transmitter LOCK button once activates alarm and central locking.
  • Pressing remote transmitter UNLOCK button once deactivates alarm (if fitted) and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button once also activates driving position memory. Driver's seat and mirrors move into memory position specified on remote transmitter when driver's door opened.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds unlocks all doors.
  • Pressing remote transmitter trunk release button for 2 seconds activates trunk release.
  • Pressing remote transmitter PANIC button for more than 1 second activates panic alarm.
  • Pressing any of the remote transmitter buttons deactivates panic alarm.
  • If vehicle unlocked and doors not opened within 30 seconds, locks are reactivated.
Synchronization.
when
  • Remote transmitter battery replaced.
How
  • Press remote transmitter LOCK button or UNLOCK button 5-6 times.
  • System should now lock and unlock vehicle to indicate synchronization procedure complete.
  • Check operation of remote transmitter
Programming
How
  • Obtain all remote transmitters.
  • Switch ignition ON.
Proceed as follows:
NOTE:Point remote transmitter at central locking signal control module (located behind glove box).
  • Within 4 seconds: Press LOCK button or UNLOCK button of first remote transmitter.
  • Within 4 seconds: Switch ignition OFF.
  • Within 4 seconds: Switch ignition ON.
Repeat procedure above twice.
  • System should now lock and unlock vehicle to indicate programming mode activated.
Within 10 seconds:
  • Press LOCK button or UNLOCK button of first remote transmitter, allowing doors to lock and unlock once.
  • Press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Switch ignition OFF.
  • Remove key
  • Check operation of all programmed remote transmitters.
Immobilizer
System Operation
  • System arms 5 seconds after switching ignition OFF. Immobilizer warning lamp flashes during this time
  • Immobilizer warning lamp illuminates for 2-3 seconds.
  • If immobilizer warning lamp illuminates for 2-3 seconds then flashes rapidly:
  • Key code not recognized.
  • Remove key and try again.
Programming
When
  • System malfunction.
  • Key added or replaced.
How
Immobilizer can only be programmed using diagnostic equipment.
Model: MDX Year: 2007-2009
Model: TL Year: 2007-2008
System Operation
  • Pressing key LOCK button once locks the vehicle.
  • Pressing key LOCK button twice within 5 seconds activates the alarm.
  • Pressing key UNLOCK button once unlocks the driver's door only and deactivates alarm.
  • Pressing key UNLOCK button within 5 seconds unlocks all doors and tailgate.
  • Pressing key UNLOCK button within 5 seconds and holding will open windows and sunroof
NOTE: Models with "Technology Package": Alarm central locking functions can be altered using digital multifunction display in instrument panel.
  • Pressing key PANIC button for more than 2 second activates panic alarm.
  • Pressing any of the key buttons or turning ignition ON deactivates panic alarm.
  • System will automatically lock all doors when vehicle is driven above 15 mph (if function selected).
  • If vehicle is unlocked and doors or tailgate not opened within 30, 60, or 90 seconds (depending on programming), locks and alarm system are automatically reactivated.
  • Pressing tailgate release button once will open, close or reverse direction of tailgate.
Programming
When
  • Key remote transmitter added or replaced.
How
  • Obtain all keys fitted with remote transmitters.
  • Ensure doors, trunk / tailgate and hood are closed and unlocked.
NOTE: A maximum of 5 remote transmitters can be programmed.
Proceed as follows:
Repeat procedure above twice. Locks should cycle when button in pushed.
  • Within 4 seconds of each other press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Remove key.
  • Wait 10 seconds.
Immobilizer
System Operation
  • System arms when vehicle is locked using the remote transmitter.
  • If key code is not recognized:
  • Engine starts, then shuts off.
  • Immobilizer warning lamp flashes once, then blinks until ignition is switched OFF.
  • With ignition switched OFF, immobilizer warning lamp will flash 10 times to indicate the system has reset.
Programming
When
How
Model: RL Year: 2005-2009
Programming
When
  • Remote Transmitter added or Replaced.
  • System Malfunction.
How
Remote Transmitters can only be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Acura Remote Transmitter Programming...
on Mar 26, 2015 | Televison & Video
98 volvo s70 glt alarm system is stuck on no key fob i unlocked it from inside and it won`t reset any tips would appreciate
Turn off the car and turn it back on, then check for any alarm buttons. Press those a few times, and try it. Also try to manually unlock the doors with the key.
Feb 28, 2011 | 1998 Volvo S70
Alarm went off , car will not start.
lock the car with the key then press/hold the lock button on the remote for 30 secs,then press hold the unlock button on the remote for 30 secs.this should reset the alarm system.
Jan 29, 2011 | 2001 Hyundai Santa Fe
I have an 08 Jeep Liberty that has a remote starter on the key. I tried to unlock the car with the remote, however, that didn't work, so I unlocked the car with the key. The alarm went off, I tried pushing...
Sounds like you have a key without the chip in it. Replacement keys without the chip will only unlock the doors and will activate the theft alarm when you start the vehicle.
May 22, 2017 | 2008 Jeep Liberty
I need to reset my car alarm on my 02 vw golf. the battery has been replaced so alarm wont unlock doors
stick key in driver door lock and unlock it. If that works, now see if the remote will unlock the door or doors..i remember reading in an owners manual once where you can program which doors open and close by they way you press and hold down the two main buttons, also after a battery change in the remote, i think, but not sure, i did this on a blazar i once owned... the owners manual said, that you had to be within 20 feet and press and hold down both buttons till it makes the arming sound.... Can i get some feedback cause im curious..thanks.
Apr 04, 2010 | 2002 Volkswagen Golf
Car alarm went off while unlocking the door, now
you need to reset alarm/immobiliser.lock car with remote, hold button down for 30 secs,then press/hold down unlock button,should reset.another way is with key in ignition/turned on, press alarm button down and hold for 30 secs.this resets immobiliser.toyota
systems vary..depending on market.
Mar 30, 2010 | 1991 Lexus LS 400
REMOTE KEY LOCK DOES NOT WORK BATTERYS NEW BUT ALARM WILL NOT SHUT OFF WHEN FIRST START .HOW CAN I DISABLE ALARM
Synchronization
When
Key buttons operated repeatedly while vehicle out of range and system becomes inoperative.
How
Carry out the following within 1 minute: Press key lock or unlock button for approximately 1 second. Manually lock or unlock vehicle. System should now lock or unlock vehicle. If not, carry out programming procedure.
Programming
When
Key added or replaced. System malfunction.
How
Switch ignition ON. Insert key to be programmed into driver's door lock. Lock vehicle manually. Press lock or unlock button. Wait at least 1 second. Press lock or unlock button again. Vehicle horn sounds to indicate correct programming. Remote controls can also be programmed using diagnostic equipment.
NOTE: A maximum of 4 keys can be programmed
Feb 09, 2010 | 2000 Volkswagen Beetle
I replaced battery in my audi 80 2.0 tdi but have lost the remote and alarm wont stop going off .
Depress lock or unlock button. Manually lock and unlock driver's door within 30 seconds. System should now lock or unlock vehicle. If not, carry out programming procedure.
Programming
When
Key added or replaced. System malfunction: Alarm LED in rear fog lamp switch illuminates for 30 seconds when vehicle is locked.
How
NOTE: A maximum of 4 keys can be programmed (one at a time).
As memory positions of existing keys are unlikely to be known: Obtain and reprogram all keys.
NOTE: Existing key memory positions will be overwritten.
Switch ignition ON. Use key not fitted with remote control. Manually lock vehicle using key. Using first key, press unlock button once (programs memory position 1). Alarm horn sounds once to indicate signal received. Wait 6 seconds. Press unlock button once to confirm programming. Vehicle unlocks. Programming mode deactivated. Switch ignition OFF. To program remaining keys into memory positions 2, 3 and 4. Carry out the complete procedure below for each key: Switch ignition ON. Use key not fitted with remote control. Manually lock vehicle using key. Press unlock button at 1 second intervals, as follows: Twice for memory position 2 (second key). Three times for memory position 3 (third key). Four times for memory position 4 (fourth key). Alarm horn sounds once every time unlock button is pressed, to indicate signal received. Wait 6 seconds. Press unlock button once to confirm programming. Vehicle unlocks. Programming mode deactivated. Switch ignition OFF.
NOTE: Ignition MUST be switched OFF between each key programming procedure
Jan 10, 2010 | 1992 Audi 80
Vehicle Parts & Accessories Logo
523 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
