SOURCE: canon image runner2200 error e000202-0001
this is error related to scanner section. The home position sensor of scanner ( copy lamp ) doesn't go of when the lamp is in home position.
You can try to manualy, few times slide the scanner rail to right and left side - BEFORE TURN THE POWER OFF AND UNPLUG THE COPIER FROM OUTLET.
If the sensor if really faulty you need to replace him.
Call service!
SOURCE: error code E000202-001
The error code deals with the scanner unit / scanning lamp. Have you just cleaned the optic's???? Was the problem there before you started to work on it? Dos the scanner lamp turn ON? I the lamp dos not come on, you will need to replace the lamp and the lamp regulator PCB at the same time as a set. Very,very important... They need to be changed as a set. If you have a working parts machine, I would use the parts from the parts copier. Good Luck
SOURCE: ERROR CODED E000202-001 CANON IRC 5185
problem with optical system.First mirror stand fails to move. May be sensor,motor or DC controller
Testimonial: "thank you for the effort sir..."
