SOURCE: Error Message
. Set shuts off after displaying the message "TV will shut down in a few seconds. Please check if the air flow is blocked." After shutdown, it may have a yellow status LED, self diagnostics indicates error code 38. To repair, replace the Lamp Thermal Sensor with the new version, part # 299P313010A. The sensor is located on the Lamp Cartridge Housing. See Service Tip VS-72B. Under rare circumstances, when a replacement thermal sensor is not available, refer to the original Service Tip, VS-72 (page 2 and 3 of VS-72B) If error 3-4 then this maybe problem:. Check to see if the lamp is on when the unit is off (in standby) if it is components on the Power PWB... K9A20 and/or K9A21 are shorted. Also, R9A02 may be open. Possible side effects ... deformed lamp exhaust duct and damaged lamp. Replace PWB-POWER part # 934C228003 and if necessary, Lamp part # 915P049010, Lamp Exhaust Duct part # 642B155010, and/or Lamp Exhaust Duct Cover part # 642B156010. See Service Tip VS-73 2. If the lamp never lights suspect the Lamp part # 915P049010
SOURCE: LCD monitor shuts down every after 2-3 seconds
dustcore025, Need a little more info here. Do you know age of monitor? Was it or did it display a "perfect' image on it the day before? Is it under warranty? How far are you willing to go to try and repair this thing? Do you know how to "part" the snap together plastic back cover from the bezel, after removing the pedestal? This sounds to me like a Switch-mode-power-supply or Inverter problem that occurs when some Electrolytic Filter Capacitors get a little bit TIRED of being constantly subjected to high temperatures near heatsinks that are used to keep semiconductors within operating limits. You can determine how bad this may be if you can do a test and remember what happens. Here is what to do. Make sure PC is fully booted displaying WIN desktop or some other screen. Next, with someone to keep hitting the CTRL or SP bar key every 20-40 seconds while you reconnect both cables of your MM17 back to the PC video port and ac outlet. Now try to turn on the monitor and note exactly what you see and for how long. Did it have a sharp clear image, even for 1-2 seconds? did the screen go black? OK! Next thing is to shine a bright flashlight onto the screen 2 inches away from where you know there was something a few seconds ago. Try it at different angles and not if you see anything. get back to me with results of test. I'm louie12fix on fixya or lmistyrel @ aol.com BYE for now.
SOURCE: LE error code
No recalls at this point. the repair man is correct. the circulation motor is damaged.
You should know that, this model has many issues that we deal with on this site that concern this (LE) trouble code. The circulation motors are not reliable in this model.
SOURCE: TV powers up initially, but shuts down within seconds.
These TV's are somewhat sensitive to internal heat. It appears your sensor has triggered an overheat. This doesnt mean you still have the heat issue, it just saying it needs to be replaced or reset, either way it is not something you can do in your home. Taking it to your local authorized shop will ensure proper repairs, about $90 worth.
SOURCE: On 2/1 and then again on 2/3 we have received an
Any heat errors on the dell 1815 means the fuser has gone bad. Your best bet is to replace the fuser, part # UG297. Here is a video that shows you how to replace it. Iteminc.com has these in stock and ships same day (till 7pm est). Hope this helps, Good luck!
