Question about Maax INFINITI HYDROMAX AIRPOOL II CORNER BATHTUB - 100055-012-W - White
Maax infinity hot tub error code clfl dont have the manual
Posted by brentmorriso on
patrolcats
    New Friend:
  • 14 Answers
Found at http://www.maaxcollection.com/Produits/ProductInfo.aspx?cat=1&fmly=1315&mdl=1851&sp=2%3b5%3b215
Click on "Installation Guides" under the "Downloads" blue highlighted box. Then download the "Whirlpool Installation and User Guide".
Quite sparse on error codes, but p19-23 have some.
...soon to be owner/user Maax Infinity bahtubber
Posted on Feb 12, 2010
Anonymous
    New Friend:
I really need a manual and don't know where to find one. Also our tub is flashing E02 and E06 what does this mean
Posted on Jan 05, 2011
  • patrolcats May 20, 2014
    http://www.maaxcollection.com/Produits/P... Click on "Installation Guides" under the "Downloads" blue highlighted box. Then download the "Whirlpool Installation and User Guide". Quite sparse on error codes, but p19-23 have some.
Water sensor needs to be replaced. 8 yr old unit. Maax doesn't carry old parts unavailable HELP PLEASE!
Parts for Maax Spas‎
www.spaguts.com/
(714) 764-0014
Pumps, packs, heaters, controls,
ozonators for Maax hot tubs.
# 27 Hot Tub Heater Replacement for 240 volt hot tubs ...
? 6:27
https://www.youtube.com/watch?v=xNWjM8c_b-8
Oct 10, 2011 - Uploaded by softcellelectrical
27 How to replace an in line or flow through heater for an above ground ... I just changed out the water in my spa when I discovered the heater element ... Is there a hose that should fit on it? ... I figure it will run similar to a whirlpool setup. ... tests on the unit...but, it sounds like 1. your sensors may be DC and
Jan 18, 2016 | Maax Home
Maax c02 error
[PDF]WHIRLPOOL BATHTUB OWNER'S MANUAL BAIN ... - Maax
www.maax.com/~/media/.../10050073_2009-04-17.p...
Translate this page Never operate the whirlpool system if there is less than 2". (5 cm) of water over the highest whirlpool jet (except for the back jets) or if the bathtub is empty.
Maax co2 error Bathtubs & Whirlpools Questions & Answers ...
www.fixya.com > Forum > Tags > co2 error > Bathtubs & Whirlpools
Maax bathtubs & whirlpools co2 error related questions and answers. Ask your Maaxquestions. Get free help from bathtub and whirlpool experts.
Maax bathtub c02 and e06 error - Fixya
www.fixya.com/support/t19321104-maax_bathtub_c02_e06_error
Aug 10, 2013 - maax bathtub c02 and e06 error - Maax URBAN 6032 HYDROFEEL AEROFEEL ... Jan 18, 2013 ' Maax Adagio True Whirlpool System.
How to Troubleshoot a Maax Tub ' eHow
Jan 05, 2016 | Maax Home
Infinity maax hot tub
all systems must be working or the spa will not heat. If one of the sensors is not functioning then the spa water will not heat.
Rod
US Parts Center
Nov 25, 2013 | Home
I have a maax hydromax tub and the temp. control needs replaced where can i buy one
Not as easily done as you would expect. What is the Model number of the Control Box under the bathtub?
We need to know that before we can match up the sensor for you.
Rod
US Parts Center
888-521-6183
Feb 11, 2013 | Maax INFINITI HYDROMAX AIRPOOL II CORNER...
Coleman Hot Tub Model 411
This spa was manufactured by Maax. Try Maaxspas.com for your owners manual.
Nov 23, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Maax bathtub Palace model Error code C01 jets don't turn on.
first of all check the circuit breakers to be sure one or both aren't kicked. be sure to turn the breaker all the way off and then fully on as a tripped breaker is in a halfway off position. if that doesnt fix your problem remove the access panel to the mechanical space in your tub. there are generally one or two reset buttons in there which can also kick off and need to be reset.
Sep 01, 2009 | Maax PALACE DROP-IN BATHTUB - 100082-000-B...
Infiniti hot tub reads HL
the pump just pumps, do you have a heater it would be about 2inch in diameter adn in line with a cord comming off of it that plugs in seperate from the pump that is the heater,
May 24, 2009 | Maax Infiniti - 100055
Error e006 maax tub water level sensor
If you are filling the tub full enough and the pumps are still not working, the level sensor is bad and needs to be replaced. One can be ordered directly from Maax out of Canada
May 09, 2009 | Maax Calla 6042 Bathtub - 101058-000
I have a Maax Calla tub that the led is flashing E06 and it has been flashing for three days.
What does this control look like? Can you email us a photo of the control?
usually that error code is a water level problem.
Jan 10, 2009 | Maax Calla 6042 Bathtub - 101058-000
Maax INFINITI HYDROMAX AIRPOOL II CORNER BATHTUB - 100055-012-W - White Logo
2,884 people viewed this question
Top Maax Home Experts
Mike
Vincent G
Vincent G
Bill Johnson
Are you a Maax Home Expert? Answer questions, earn points and help others
