20 Most Recent Maax Studio 1-Piece Hydromax Whirlpool Tub Shower with Drain & MAAX IES 1/2 Questions & Answers
We purchased a home with the Maax Hydromax
http://www.homeclick.com/web/catalog/product_detail.aspx?pid=27963&ven=3726866
This is the only site i could find they might be able to get the info for you
2/5/2011 6:28:29 PM • Maax Studio... • Answered on Feb 05, 2011
E06 error--how do you get rid of flashing this
Finally resolved this on our own tub. We had C01 and E06 error alternating. After gaining access to the service door for the tub, I was able to determine that the ribbon cable for the water detector going to the electronics box on the back of the pump had become loose. After plugging it back in and then powering off/on the pump, the blinking light on the back of the pump went back to solid and the error on the control panel eliminated.
10/11/2010 7:51:17 PM • Maax Studio... • Answered on Oct 11, 2010
Cold water and jets don't
Likely your mixer valve cartridge has a blown o-ring.
Replace the cartridge.
Jets not working may be as simple as the GFI outlet being tripped.
Thanks
7/13/2009 6:41:39 PM • Maax Studio... • Answered on Jul 13, 2009
Jacuzzi
you have to call the maker of your unit because the gasket can start leaking if you use the rong kind of cleaner
12/12/2008 8:15:19 PM • Maax Studio... • Answered on Dec 12, 2008
Maax Rainforest shower model 4343. Where do I find a cartridge for it please?
Question edited for clarity. Combine 3 posts into 1 Post. Delete two duplicate posts. Refresh page to see your question. Better to order direct from Maax to be sure of the part and get warranty. They are expensive. Model 4343 doesn't appear to be a valid product https://www.google.com/search?q=Maax+Rainforest+shower+4343+parts
Shower And Door Replacement Parts - Maax
Maax https://maax.com > services > replacement-parts You can now buy shower replacement parts for MAAX showers, doors and kits online. Shop Now. Find the replacement part you need. Missing: 4343 ‎' Show results with: 4343
MAAX Canada https://maax.ca > services > replacement-parts You can now buy shower replacement parts for MAAX showers, doors and kits online. Shop Now. Find the replacement part you need. ..
4/17/2024 9:35:22 PM • Maax Plumbing • Answered on Apr 17, 2024
MAAX Saninova control panel
To find out more about replacement components, get in touch with MAAX directly or go to their website. You might be able to obtain the precise control panel you require from one of their authorized dealers or distributors.It will ensure you get an original one
8/14/2023 11:44:32 AM • Maax Plumbing • Answered on Aug 14, 2023
2answers
Do I need to Cement under my Maax shower pan? 60 x42, 3 height
This video doesn't show needing cement - Maax Professional Installation Video KDS Series
7/11/2018 10:03:04 AM • Maax Plumbing • Answered on Jul 11, 2018
My maax pivolok door wont fit in the opening they said to make it
and what is your question --if you want to complain notify the company
4/30/2018 1:26:46 PM • Maax Plumbing • Answered on Apr 30, 2018
How to change overhead light in maax shower?
There are 2 types of litghly cover. A twist off (1/4) turn and a some pry off. It shouldn't be required hi torque. Try twist off first counter clockwise
6/2/2017 10:01:33 PM • Maax Plumbing • Answered on Jun 02, 2017
Drain stuck in closed position
Generally the drains that are controlled from the OVER-FLOW do indeed have a rod that goes down from the face of the overflow... which lifts (opens) the drain by lifting a hollow (typically plastic) sleeve from in front of the outflow of the drain... It is hollow to allow the OVERFLOW to work at all times. The version you seem to have... WOULD have a bellows like device that pushes on a plug lever... More complex... but I seriously believe both may be serviced through the OVERFLOW (will attach a drawing below)... OBVIOUSLY you will want to block the drain before rolling & dropping screws in, on & around the drain HOLE... Once you see the diagram of the drain MECHANISM... you will be able to see that jamming in a coat-hanger was a terrible idea. You can still most likely remove and repair the mechanism ... (from the over-flow) ELSE You are looking at buying a new one and installing the entire drain from the bottom (hopefully). Diagram of drains: Go to Bing homepage Carnac the Magnificent
3/24/2017 7:47:36 PM • Maax Plumbing • Answered on Mar 24, 2017
I just had a Maax Living tub installed but did not receive a manual. I searched the Maax website but could not find the answer I need: if I accidently push the drain, the water starts draining but I c
Good tips, but I haven't seen this answered yet. We just bought a house with a Maax tub. The drain is not a pop down, pop up deal. You push in a button in the overflow to raise the drain plug. But the vacuum of the drain pulls it down again. So you have to hold the plug in the entire time it takes to drain. I'm told something can be adjusted for this, but I'm not a plumber, and so far it's not obvious.
8/1/2015 10:03:03 PM • Maax Plumbing • Answered on Aug 01, 2015
Hi, i have a 40x60 base model 01225002. Could you tell me how much motar to put in place and any tricks you can give me on how to do it.
Use structo-lite. Its easier to work with and much lighter. You want enough to make contact with the bottom of tub.
10/28/2014 1:59:04 AM • Maax Plumbing • Answered on Oct 28, 2014
Shower bottom rollers
www.maax.com
8/20/2014 7:47:46 PM • Maax Plumbing • Answered on Aug 20, 2014
Shower installation instructions
look at the new frame to see how thick it is
6/7/2014 3:11:21 AM • Maax Plumbing • Answered on Jun 07, 2014
Heater is not working on a brand new maax whirpool
If it requires 110/220 volts and was wired to a double breaker... check to see that the do-it-yourself electrician put the breaker in a location that will give 220 volts and not 2 parallel feeds on the same side of the panel. Or else turn the double breaker off and then on to reset it.
10/15/2013 2:22:13 AM • Maax Plumbing • Answered on Oct 15, 2013
How can I fix a Moen faucet 1225 in the kitchen?
Question edited for correct spelling of maker 'Noen' to 'Moen'. 'Fix' as in it is leaking? Or tighten it down because it is wobbly, or something completely different?
Moen One-handle Replacement Cartridge -- 1225
MOEN https://www.moen.com > products > Moen > 1225 From finishes that are guaranteed to last a lifetime, to faucets that perfectly balance your water pressure, Moen sets the standard for exceptional beauty ... "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(62px);"> Rating: 4.4 · ‎ 31 reviews · ‎ US$33.35
M-Line Moen cartridge -- M1225
Moen https://www.moen.ca > products > M-Line > M1225 Moen Cartridge · Designed for 1 Handle lavatory, kitchen and tub/shower faucets (after 1959) · Replaces O.E.M. 1225 · Backed by MOEN's limited lifetime warranty.
MOEN #1225 Single-Handle Faucet Cartridge
Home Depot https://www.homedepot.ca > ... > Faucet Cartridges It maintains a balanced pressure of hot and cold water. This cartridge assembly is ideal for Delta Monitor 1300 and 1400 series tubs and showers. See less ... In stock
Moen 1225 One-Handle Kitchen and Bathroom Faucet ...
Amazon.ca https://www.amazon.ca > Moen-1225-One-Handle-Repl... Replacement faucet single control cartridge; Fits all single-handle kitchen, lavatory, tub, and shower Moen and Stanadyne faucets; Eliminates hard pull ... "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(62px);"> Rating: 4.6 · ‎ 5,065 reviews · ‎ $33.34 · ‎ In stock ..
3/25/2024 10:23:56 PM • Plumbing • Answered on Mar 25, 2024
2answers
Do you give memenars about pumps
Well, we can have a one on one seminar by the internet.
I've been a pumpman for 20 years. I can share with you
my experience (household pumps, suibmersible pumps,
turbine pumps, gear pumps, piston pumps, dewatering
pumps, mud pumps, trash pumps, mining pumps,
solids handling pump, etc....) Just take your pick. Just
send in your e-mail for assistance. God bless.
1/17/2024 9:59:21 AM • Plumbing • Answered on Jan 17, 2024
Maax Studio 1-Piece Hydromax Whirlpool Tub Shower with Drain & MAAX IES 1/2 Logo
Popular Tags
18 questions posted
Top Maax Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Maax Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Maax Plumbing
  • Maax Plumbing
Most Popular Question
e06 error get rid flashing
  • Plumbing
